Question about Hotpoint VBXR1090D Top Load Washer
Washer wont drain or spin
Washer will not drain for the rinse cycle or will it spin it will stop and i just hear a hum noise so i know its on but it wont do anything durn rinse cycle and then it goes back to washing
  • leeroyTWB May 24, 2009
    My pump was clogged...saved 60 bucks by reading this post, thanks!
  • 105 Answers
It sounmds like there is a clog in the pump. If the washer won't drain, it will never spin. Remove the front panel by sliding a putty knife between the top and the front panel. The pump is located on the right side as you face the machine. Unplug the machine and be prepared to catch the onslaught of water as you remove the hoses. The pump may be clogged as you will see once you rmove the hoses. If so, clean it out and test. If the pump is bound and will not move it may need to be replaced.
Posted on Apr 17, 2009
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Kenmore washing machine catalyst stops during rinse cycle
The hum you here is the probably the motor trying to turn, but it is about burned out. If it moves a little with a full load and more with no load, it is probably bad. If you hear a hum and the drum never moves at all you probably have a broken belt.
May 19, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer model 12502100 goes into rinse cycle fills with water turns then stops. won't drain just stops hear humming or buzzing noise.
Try to put it on rinse on another cycle, like normal, heavy duty or delicate. If it works, then your timer is probably bad. If it doesn't work then maybe the pump. Best of luck
Mar 21, 2010 | Washing Machines
Washer souds like trying to engage but won't
If the motor hums and will not pump out or spin, the motor is bad. It reverses direction and the reverse windings appear to be burned out.
Dec 28, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer not spinning/draining
The lid switch is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Hotpoint VBXR1090D Top Load Washer Logo
307 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
