Question about Saeco Vienna De Luxe Espresso Machine
Grind settings on a Saeco Vienna Deluxe is the fine grind a high number setting or low number setting? also, what is the knob for that has the (+) and (-) symbol?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
The factory setting should be 8. The higher numbers are finer. The + and - knob is the doser amount, the amount of coffee in a shot dose. Average is 7 gm, the middle. The highest is 14, I think. Generally, the highest dose shouldn't be used consistently because it can cause stress on the brew group. Just brew two shots.
Posted on Apr 19, 2009
I have a Saeco Vienna Delux, coffee is being grinded but it is not making its way out. I removed the nozzle which divides coffee into 2 but a few drops are coming out. what can i do?
Hi
I think this will help you.
There are a couple of things on a delux that can cause this.
Your grind is to fine ( the big knob in the bean hopper is below 8. If it is turn the big knob to a larger number. You can turn the big knob any time but it has to be grinding to turn it to a smaller number. 3 cycles before it has changed the grind in the brew unit. You can push the button to stop so you don't have to wait for it to finish. If that is not it go to the next solution.
http://www.fixya.com/support/r9150937-vienna_not_make_coffee_or_very_slow
May 07, 2011 | Saeco Vienna De Luxe Espresso Machine
Coffee drips very slowly and descaling not helping
I had the same problem. Check and make sure your dose is not turned up too highor your grind is not set too fine? Turning the dose knob clockwise decreasesit. I have ended up with my grind set on 13 which is more coarse than averagefor the beans I'm currently using. Adjust the grind while the grinder isworking by one number and then brew 3 or 4 coffees before changing it again. Ittakes that long for the grind to be seen in the coffee. The higher the number,the coarser the grind will be. Any time you use different beans it is possiblethat you'll have to reset the grind.
Oct 31, 2010 | Saeco Vienna De Luxe Espresso Machine
Red warning light comes on in my saeco vienna deluxe I just aquired this unit and to date have not been able to make a cup of coffee. All the green lights light up and coffee starts grinding but after that...
Hi
More than likely your grind is to fine and you are using oily beans (shiney). There is a small knob in the bean hopper. turn it down to the minus side. Turn the big knob to the # 18. If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 07, 2010 | Saeco Vienna De Luxe Espresso Machine
Our Saeco Vienna Deluxe will not stop grinding. Any ideas?
Hi
3 things
1. Grind is too fine. Move to a very coarse grind, say 16.
2. Move the small knob to the - side and try again.
3. If that didn't work your going to have to clean you grinder.
Need instructions? email me.
Jan 05, 2010 | Saeco Vienna De Luxe Espresso Machine
Grinder settings for Vienna Deluxe
Hi
To start off with, you should not change the big knob unless the grinder is operating at the time.
Set the small knob to the middle position. You can move this any time. Move towards the + mark to strengthen the coffee, but never all the way to the full +.
Set the big knob to the #8 to start off with. Move it 1 # smaller to make the coffee stronger but be careful not to get it to fine as you will clog the grinder and you will have to take it apart to clean. If you ever get an out of beans light, but there are beans in the hopper, open the knob to #16 for 1 cycle, then turn it back down to a # 1 larger than you had before and leave it unless you get the message again. Shiny beans call for a coarser grind than a dull bean because of the oils in the coffee bean. Oils will cause the grinds to stick together and cause clogs faster than beans that have less oil.
Jul 16, 2009 | Saeco Vienna De Luxe Espresso Machine
Change the grind in Saeco Vienna Deluxe coffee maker
Hello kgspco.
You will need to work the 'dial knob' untill it free's it-self.
The higher the number the Coarse(r) the grind.
If you want rich - dark - strong coffee, set number between 4 - 8.
(if you can free it up - keep trying
Jul 06, 2009 | Saeco Vienna De Luxe Espresso Machine
WEAK espresso from Saeco Vienna!
Well, when you set it that low it allows the water to pass very quickly and if the water passes very quickly there may not be sufficient time to absorb the coffee; hence weak coffee. The setting should be reset to the middle, at 10, and tried again. Then, if you want to change it move it only one or two numbers for enough cups to see if there is any change before you move it a large number. Going higher or lower makes it pass more or less quickly with results accordingly.
You may also have the dose set too low and you may want to set it higher increasing the amount of coffee in each dose.
Then again, since it was used, you don't know if the machine was taken apart by someone who reinstalled the machine with the dials you are using out of whack with where they should be set.
George W Conrad.
Apr 02, 2009 | Saeco Vienna Espresso Machine
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Slow coffee drip
did you change coffee different coffee different setting lower our coffee setting move it only when it grinding only cheers
Dec 07, 2007 | Saeco Vienna Deluxe
Saeco vienna deluxe espresso machine
adjust the water flow look for a knob that turn right to left minus less water plus more water
Jun 08, 2007 | Saeco Vienna Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
352 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
