I am trying to upgrade the memory on my Phillips LS1200 PC but cannot get the side off the box. I have removed the two rear thumbscrews but the panel will still not come free. How can I overcome this problem? Are there some hidden catches somewhere?
  • jlishman450 Apr 18, 2009
    The proposed solution has not worked. The removable panel is on the left hand side of the computer looking at it from the front. I have removed the two thumbscrews and tried to pry the panel loose per your suggestion but without success. I think there may be a hidden catch, or catches, somewhere that must be released before the panel will slide free. For further information if it will help the computer is a desktop Phillips Freeline LS 1200 PC S/N 4000333100076
    John.
  • jlishman450 Apr 21, 2009
    Yes but in addition to removing the screws I found that a block of wood and a light hammer tap on the front of the panel solved the problem
  • 13,433 Answers
Try to push or pull the side panel out towards the back of the case if your unable to then unscrew all screws you find and see if you can remove the front panel from the case.
Posted on Apr 18, 2009
    Brigadier General:
  • 5,158 Answers
It has two side panels that can be removed correct. if that is the case and you have removed any screws holding that panel... you will need to take a flat blade screw driver... gently pry the top lip of the panel at the rear of the case.. till it moves slightly.... then move to the bottom and repeat that... you may have to shift to top and bottom again... but it will slide off
Posted on Apr 17, 2009
HOW TO REMOVE FRONT PANEL OFF THE GATEWAY ESSENTIAL
  • Remove the side panel first to make the front bezel easier to access. To remove the side panel, remove the thumbscrew from the side panel cover. If the thumbscrew is very tight you may need to use a screwdriver to loosen it.
  • Lift up the release lever to loosen the side cover. Carefully swing the panel away from the computer and lift the panel away. Set the panel aside.
    Move the computer slightly forward on the desk so that the top and the bottom of the case are both accessible. Pull the bezel out and lift it free of the case. Set the front bezel aside until it is time to reassemble the unit.Read more: http://www.ehow.com/how_5775555_remove-panel-gateway-e_series-computer.html#ixzz2pxkABtPy
    Jan 04, 2014 | Gateway Computers & Internet
    How do i remove cover
    Viewing FRONT of computer the LEFT Side panel removes.
    Viewing REAR of computer there are two Thumbscrews to loosen.
    One towards the Top, one towards the Bottom.
    (Not supposed to come all the way out, but OK if they do)
    There is a 'bulge', or 'bump' formed at the back of the Side Panel.
    This is a fingerpull handle.
    Pull back on the Side Panel towards the Rear of the computer.
    The Side Panel will only slide so far. This is because there are metal L-shaped tabs formed out of the Side Panel, that go into slots in the metal framework, of the computer case.
    The L-shaped tabs are like a hook. You may have to ease the Side Panel a little forward, then the L-shaped tabs will clear the slots, and the Side Panel can be brought out to the side, and removed.
    Anti-Static Precautions:
    Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
    Relieve your body of Static BEFORE reaching inside your unplugged from power, computer.
    Computer on a table, computer unplugged from power, computer case open;
    TOUCH an unpainted surface, if the metal frame of the open computer case.
    This action will relieve your body of Static.
    IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
    May I ask what the problem is, or is this for a simple upgrade?
    For additional questions please post in a Comment.
    Regards,
    joecoolvette
    Nov 07, 2012 | Acer Aspire T135 PC Desktop
    Opening pc tower
    Try this:
    Download the manual it will have the instructions on how to remove the panel.
    http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
    Aug 17, 2012 | eMachines ET1641-02w (PT.NA60X.001) PC...
    Rear panel for a mitsibishi montero speacker removel
    1Lift the rear seat all the way up and towards the front of the vehicle.
  • 2Remove the five Phillips screws holding the scuff plate at the rear opening of the vehicle. Remove the scuff plate.
  • 3Use a panel tool to pry off two screw covers on the edge of the headliner in the cargo area. Remove the Phillips screws located behind each of the covers.
  • 4Pull the carpet away from the edges of the rear-side panel. Remove four Phillips screws located below the carpet at the bottom of the rear-side panel. Remove the two Phillips screws holding the cargo cover hooks located on the rear-side panel.
  • 5Pry around the bottom and back edges of the rear-side panel and pull the panel out far enough to access the speaker.
  • 6Remove four Phillips screws from the edge of the speaker with a Phillips screwdriver. Pull the speaker out of the door and unplug the wiring harness connected to the back.
  • Nov 12, 2011 | 1995 Mitsubishi Montero
    How do you take apart the tower
    Turn the computer off.
    Disconnect the AC power.
    Look at the "back" panel.
    You might see thumb-screws that hold the side-panels in place,
    or you might see Philips-head ("cross") screws.
    Or, you might see plastic "locks" -- slide them 1/4 inch to "unlock" the side-panel, and lift it off.
    Or, look at the side-panel -- there may be a "lever" (like a "tab" on the top of a pop-can) that can be lifted to release the side-panel.
    Or, older towers had a "one-piece" cover (like an upside-down "U") that needed to be unscrewed, pushed slightly towards the back ot the case, and then vertically lifted off.
    Aug 29, 2010 | Gateway GT5220 PC Desktop
    Where does the video card go in a t3302 model emachine?
    This particular model have AGP expansion slot located on motherboard, as this is rather obsolete computer, I am not sure if this is financially viable solution.
    You will need phillips screwdriver.
    To proceed with upgrade:
    1. Switch off computer,
    2. Remove power cord and monitor cord, if you want, you can disconect all remaining cords as well, but only if you are moving computer elsewhere.
    3. Remove two thumbscrews holding left side (grill) panel, then slide it back and lift off
    4. AGP slot is located below processor, just above white PCI slots, it is offset slightly towards front of the computer. If there is little screen mounted in first hole, remove it, depending how it is mounted by either, removing of the screw, or breaking it from the case.
    5. Orient your card and insert it firmly in AGP slot, card should fit snuggly without bending or excessive force. Use screw to mount it to the back of the case frame.
    6. Connect all cables, monitor cable to new installed video card, start your computer and check if there is display, if you have BIOS display, switch off computer, you installed your video card correctly.
    7. Replace side moving it in reverse to removal, hung it first on the top and then slide forward, secure it back with thumbscrews.
    8. Start back your computer
    9. Install video drivers and setup your display to desired resolution.
    Enjoy!
    If you need manuals and settings for this model, these are availbale at this acer site:
    http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3302
    Aug 06, 2010 | E-Machines T3302 PC Desktop
    Opening the case of the Poweredge 5000SC
    You would need to unscrew the thumbscrew located on the right side of the rear panel, press top and bottom cover release tabs and pull the cover toward you. To replace, perform the steps in reverse.
    Good Luck
    C2Solutoins
    Jan 25, 2010 | Dell PowerEdge 1600SC Server
    How do I get to the memory sockets on an HP Pavilion 6736?
    1) Computer unplugged from Power
    2) Viewing the rear of the computer case there is a Thumbscrew you loosen. It is on the Left side, approximately half way up. Doesn't come all the way out. (Shouldn't)
    3) Above the thumbscrew you will see a 'Bump' in the side case cover. This is a place to put your fingers, when pulling back on the side panel.
    Thumbscrew loosened, pull back on the side panel. If memory serves the side panel only comes back so far, then it is lifted up, and out.
    If I may;
    BEFORE you reach inside your computer, I advise you should follow some simple Anti-Static guidelines.
    Static electricity will FRY out computer hardware components.
    You won't see it, or feel it.
    Computer unplugged from power, computer case open, TOUCH the metal frame of the computer case.
    That's it.
    This will relieve your body of Static.
    Should you get up for any reason while working on your computer, leave, then come back, Touch the metal frame again.
    Touch the metal frame before, you take the new ram stick/s out of their protective anti-static bag/s.
    If you are already aware of the above, please disregard it.
    Regards,
    joecoolvette.
    (In case my solution explanation was not clear enough, here is HP Support, and how to open the computer case style you have,
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00968217&cc=us&lc=en&dlc=en&product=3872247
    Jan 07, 2010 | HP Pavilion 6736 PC Desktop
    How to replace screen on Pavilion dv7-1040us. is diferent from other hps I have replaced, cannot figure out how to remove it.
    Here it is! Have fun!
    1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
    2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
    3. Lift the LCD panel out of the display panel enclosure.
    LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
    1. Place the LCD panel into the display panel enclosure.
    2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
    3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
    To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
    Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
    Before you begin: Remove the battery2_bing.gif.
    1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
    2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
    3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
      Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
    4. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
    5. Place the wireless LAN Minicard in a static dissipative bag.
    Before you begin: Remove the battery.
    3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
    4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
    5. Turn the notebook right side up and open the display panel fully.
    6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
    7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
    8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
    Keyboard replacement
    1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
    3. Toe the tabs on the bottom edge of the keyboard into the top cover.
    4. Press the keyboard flat.
    5. Close the display panel and turn the notebook upside down.
    6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
    7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
    8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
    9. Tighten the two captive P1 Phillips-head screws.
    Dec 09, 2009 | HP Pavilion dv7-1240us Notebook
    Opening side panel of acer aspire t180
    You have done half the work toward the solution by removing the thumbscrews. The other half involves sliding a spring-loaded lever above the lower thumbscrew toward the bottom of the case. While the lever is slid toward the case bottom, push on the side panel in the same direction as the screws, i.e. toward the rear of the case. The side panel should slide just slightly, allowing you to then lift it off to access the inside. Note that when replacing the side panel, follow the above steps in reverse order.
    When replacing the side panel, note that if the panel is not correctly replaced, the thumbscrews will not be able to be installed as the lock lever will not be set properly.
    Jan 23, 2009 | Acer Aspire™ T180 PC Desktop
    Computers & Internet Logo
    54 people viewed this question
    David Payne
    David Payne
