Question about Epson GT 3000
Epson GT30000 Document feeder error
When i close DF and touch ''print'' botton,an error ligth flashs.What is the problem and how do i reset it.
  • 526 Answers
If the ready light is off, and the error light is flashing, it indicates an interface error. please check all your cables.
Posted on Dec 20, 2009
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
Epson workforce 600 error message; please clear document feeder
Hi there.
Still there might be traces of dust or small paperpiece somewhere.
Iceman.
Nov 10, 2009 | Epson WorkForce 600 All-In-One InkJet...
Paper is getting jammed in the document feeder
This problem occur due the DF is not detecting the Orginal size.
Check the Size detection sensor,located when u open the ADF cover u can see, Clean the sensor by blowing.
Aug 12, 2009 | Gestetner - DSm675sp Digital Imaging...
Hp officejet 7310
better u disconect ur document feeder wire connection. and than try that.
Aug 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder does not work
cleaned some sensors under the feeder, if possible, clean it with blower to solve the problem.
Aug 04, 2008 | Canon NP 6050 Copier
Blinking both the ink botton ligths and the botton paper
I just today threw away my R220. If your 2 red lights are going and the power light is off, then your printer has died. It just happened to me. It sucks, but there is no way to fix it.
May 04, 2008 | Epson Stylus Photo R220 InkJet Printer
Message d'erreur sur la Kyocera
Make sure document feeder cable screws are tight and if cable guard (metal bracket) is not installed make sure it is not too close to the wall.
Mar 27, 2008 | Kyocera CS-2550 Black and White Copier
Cover door for document feeder not closed
possible cause is that you have broken the DF door tail that senses the door closed. Check by opening the cover you should see a slit with either a switch in there or a light sensor. Push the switch down using small flat blade screw driver or if light sensor place a folded piece of paper in the gap.
Either one should then recognize that the door is closed.
Hope this can help and if this does work will need to replace the door.
Dec 26, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
320 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
