Question about Cuisinart DGB-600 Coffee Maker
Grinder bottom piece cannot be removed
I have owned this coffee maker for nearly 4 years, and love it. This morning, however, the bottom piece of the bean grinder will not come out of the unit. I don't know why it's stuck. Has anyone else ever encountered this?
  • 4 more comments
  • Anonymous Nov 04, 2007
    I have the same problem. Do you have a solution yet?
  • Anonymous Nov 23, 2007
    We have recently noticed this problem as well. I try to push it forward and sometimes it comes out OK. There are other times that it pops right our and then there's times I have to use a few choice words.
  • kathy 51 Dec 14, 2007
    Right, I have the same problem--and so does a neighbor who has the same coffeemaker. I love the coffee maker, but it is quite a nuisance to fight with that bean grinder part. I always take the thing apart and clean it religiously. I think the problem started after it had sat for several weeks without use this summer. Sometimes I can get it to release when I pull up (firmly) on the side nearer the back of the pot. I'm still hoping for solution from someone.
  • Anonymous Dec 26, 2007
    Same problem - have to use a pair of channel locks to remove the grinder. Ordered a new grinder (as well as a new carafe) from abtec parts thinking perhaps the plastic inside the grinder had become misshapen. New grinder (with metal connector) has the same problem. What can be causing this?
  • smedvigy Dec 31, 2007
    Yep. Same problem. Probably using the same choice words as the other writer!
    Was thinking of ordering a new grinder piece from Cuisinart, but if that won't fix it, maybe not.
    Will call Cuisinart and if they have any solutions, will post here. Too bad the contraption (called R2-D2 in my house because of the beeping) makes such terrific coffee...I'd have chucked it a long time ago otherwise!
  • Anonymous Mar 24, 2009
    i dry religiously and have the same problem. this is just BS! i paid too much for this maker for it to be trashed!!
    New Friend:
If you open the door in the front and remove the straining basket you will see an open space where the very bottom the grind cup sits. Take a long thin standard head screwdriver and insert it there until you feel the post of the grinding engine against the screwdriver. Turn the screwdriver like you are turning a screw. The grind unit should start to move up. You can try to use the screwdriver to pry upward to finish the job. Another post said that redrilling the brass post insert on the grind cup worked for him. The problem seems to be the grind motor post that has swollen or been misshapen through the use of the machine. If they were to ask me, there is a better design for this contraption, just look at any blender. Flat disks with downward (or upward) facing fingers on the removable container and the motor.
Posted on Dec 14, 2011
Use short end of a allen wrench (L shaped tool) to pry off. Insert under grinder bottom push on longer side of allen wrench
Posted on Apr 24, 2009
If the grinder has not been taken apart for a while there maybe something like a mechanical weld between the post of the motor that turns the grinder and the receiving piece at the base of the plastic grinder cup.
Careful, yet forceful pulling will separate the two. I used lock grip pliers opened just wide enough not damage the plastic cap in the grinder cup but closed enough to allow you to pull straight up. Afterward use a cotton stick to dry the two before pressing them together.
The humidity from each brew cycle can contribute to the stubbornness of the grinder motor post and the receiving stem of the blade.
Posted on Dec 26, 2007
SOURCE:
After cleaning my machine I am left with the classic one extra part when reassembling. The part is a black rubber ring, a little less then 2" around, one end has 4 slits. I think it may fit over the...
HI
It fits on top of the grinder and under the bean hopper. There are 4 ridges on the grinder that it fits on and seals the grinder to the bean hopper. Just remove the bean hopper and put the rubber piece on the top of the grinder.
May 09, 2011 | Saeco Vienna SuperAutomatica Coffee...
I have the grind and brew thermal coffeemaker. The water does not get hot enough for steam to come off of the coffee when it is poured.
Hi, I have owned that coffee maker for years.
After it brews coffee, it does not have a warmer to keep it hot. It has a thermally insulated carafe. Such as regular lunchbox thermos jugs have. The reasoning behind this is that coffee heated after it is brewed spoils in a short time. (Of course, unheated coffee gets cold).
What that translates to for you with regard to no steam is this. As soon as the coffee maker finishes brewing your coffee, open the top of the carafe, stick in a spoon and stir it.Then pour it. (I learned the stirring part working in a restaurant).
If you have to wait before you drink it, do the same. Stir it first.
Hope this has been helpful
Love that grinder!
Best Regards,
Mark
Jan 04, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Cannot remover the coffee grinder from machine.
Remove Coffee Maker's top cover. Slide coffee bean container off (after emptying it of coffee beans). Remove fixing screws (normally philips) securing the bean container platform. Remove grinder's bean intake rubber seal. Unscrew the grinder's fine/course selector, paying close attention to where it was originally fixed, from factory. 4 rubber bushing are anchoring the grinder in place, which can be seen from the front of the Coffee Maker (w/ door opened). Wiggle each rubber bushing through, as you pull grinder from the top. Grinder should come loose, after unplugging wires. - Good Luck
Nov 13, 2010 | Miele Coffee System
Display saying GRINDER
my machine does not say grinder block but it saying coffee bean holder is empty when it is full.
Aug 03, 2010 | Gaggia Titanium Espresso Machine
I have had my Bunn for 5 years and have loved the convenience of the 3 minute coffee, plus the coffee is always great, but for the last 6-8 months it has been leaking from the bottom. I go to work very...
Most likely the problem is in the water intake area. I have the same problem, I took my machine apart, removing the top revealed a plastic water chamber which leads to a connector that lets the water go into the heating chamber. The seal had become brittle, and the plastic water chamber also was degenerating where it met the heated water chamber. I replaced the rubber seal and that worked the first time, however, I think the plastic has now deteriorated to the point that I will need a new reservoir piece and a new seal. It's probably time to send in the unit for repair.
I think one repair for a 25-30 year old coffee maker sin't such a bad deal!
Feb 14, 2010 | Bunn NHB Coffee Maker
Incanto sirius states grinder blocked. Took apart
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
DGB 500 Grinder
You may try opening the front cover first and removing the filter then after opening the top lid, remove the clear grinder cover and lift the grinder from the rear. After you get it out be sure to clean the motor drive shaft and the bottom of the grinder. then use a trace of vegetable oil to lubricate the motor shaft where is attaches to the grinder.
We are on our second coffee maker and it makes great coffee.
Jan 19, 2009 | Cuisinart DGB-500 Coffee Maker
Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Aug 31, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Saeco vienna superautomatica
oily coffee residue on the grinder prevent the bean from going down be carefull push coffee down in the grinder with anything except our finger by forcing coffee down will making expresso it should grind if it does remove the coffee cointainer little star screw driver after removing the container inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that put back without old coffee stuck on the grinder you gonna see the coffee gonna go down in the feeder cheers and if it help you dont forget to rate this cheers
Jan 23, 2008 | Saeco Vienna SuperAutomatica Coffee...
Coffee will no longer grind.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
Aug 21, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
674 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
