Question about PPI DCX-600.4 Car Audio Amplifier
AMP the short protection is coming on and is getting REALLY HOT REALLY FAST.
  • 631 Answers
If the amp gets hot or goes into protection with no input signal and no speakers/wires connected to the speaker terminals, the amp likely has shorted output transistors. It's not a complex amp. Any reputable shop should be able to repair it.
Posted on Sep 19, 2007
SOURCE:
It will turn on with both dvd and sat connected for audio but after about 15-30 it will shut off on its own
It really shouldn't matter what inputs are attached but...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 17, 2011 | RCA RT2870 Theater System
Technics seperates not turn on just shows problem f61
ALL of the (unidentified) separates do that? How separate are they, really?
F61 usually means the amp has detected a short or a severe microprocessor error.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 24, 2011 | Audio Players & Recorders
Sony receiver (STR-DA80ES) is in protected mode and stays there. Might need new amp board (part number A-4403-068-A)
Or it might be something simple. Since you don't reveal the steps you've taken to isolate the problem...
But you probably knew all that.
Search engines find that part if you REALLY want it:
http://www.partstore.com/Model/Sony/Sony/STRDA80ES.aspx
Jun 29, 2011 | Sony STR-DA80ES Receiver
My denon pma 355 keeps going into standby,it has always done so when it gets very hot,it is now doing it much more frequently,sometimes after only 2-3 minutes use
You might want to get an understanding of why it gets so hot. It's not toaster. Repeated thermal stress wil eventually kill it.
Jun 04, 2011 | Denon Audio Players & Recorders
Amp is getting hot too fast and too much
check all of your connections to ensure that you dont have a short, even a single strand is enough to short but possibly not enough to make the short circuit protection to kick in, also check your earth cable, make sure it is attached to clean metal and is a nice thick piece of cable, check your speaker specs to make sure they match your amp, turn down the gain a bit if you have turned it up high and maybe get some thicker + cable to run from your battery, big amps need big current, this means nice thick cables to try to hide but its worth it. No point hooking up a big amp with skinny little cables. Could cause the amp to try too hard to make up for the lack in power.
Hope this has been helpful.
May 05, 2011 | Performance Teknique ICBM-779 Car Audio...
I have an Onkyo ht-520 all of a suddeen it won't turn on. Can this be fixed without a repair shop
That depends what's really wrong.
Apr 29, 2011 | Onkyo Audio Players & Recorders
Can not get protection mode off audio control centre need code or button
No, you need to resolve the reason it's self-protecting or get it fixed (same thing).
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
Feb 28, 2011 | Audio Players & Recorders
I get protection error and automatically shutdown . How do I fix it?
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 22, 2011 | Samsung Audio Players & Recorders
PPI DCX-600.4 Car Audio Amplifier Logo
115 people viewed this question
Top PPI Car Audio & Video Experts
Mike Duncan
Mike Duncan
Anthony Ward
Anthony Ward
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
