Question about Lexmark All-in-One Printer with PictBridge
Alignment of cartridges
I have a lexmark X2650. I have put a new black ink cartridge into the printer and gone through the alignment process. It is printing the aligment pages fine. But everytime I try and print this alignment message comes up. The cartridges are in fine and I don't understand why this keeps happening
  • Lexmark Expert
  • 228 Answers
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Posted on Apr 17, 2009
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
Lexmark x2650 isnt recognising the black ink cartridge
There could be two reasons for this 1. take out the black ink cartridge make sure you have taken the plastic sticker off. 2. The contacts at the back of the cartridge might be damaged. in which case you will have to get a new ink cartridge.
Mar 30, 2011 | Lexmark X2650 All-In-One InkJet Printer
Where can i put lexmark ink?i can't see the place where should i put the new ink for lexkmark x2650
Make sure the Lexmark X2650 printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will move to the center automatically for the loading position.
Press the down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Nov 06, 2010 | Lexmark X2650 All-In-One InkJet Printer
Alignment problem on lexmark x4650 printer
Try this
Turn off you printer
remove the cartridges
and try gently moving the ink cartridges carrier from left to right
for about a min.
also you can try to wipe machine oil on the bar that holds the ink cartridge carrier
then put the cartridges back inside the carrier
then turn on you printer
and try to print again
If problem persist
TRY THIS:
turn off your printer
unplug the power cable from the printer
lift you printer and put it in an upside down position
then shake the printer from left to right
see if there's any foreign objects stuck inside the printer
Feb 25, 2010 | Lexmark X4650 InkJet Printer
I installed new cartridges and I'm still getting a message. "cartridges replacement required" It's a Lexmark X2650 printer
did you put in new cartridge or refill the old? If you bought new ones you could have gotten one with a bad chip. I would take it back and exchange it for a different.
Oct 01, 2009 | Lexmark X2650 All-In-One InkJet Printer
Put in a new black ink cartridge #32 in my lexmark X5470
Try arrowing down on your screen to maintenance press the tick to select maintenance and then scroll down to align catridges. see if this works
Jun 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
Still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
Lexmark X2650 All in one printing only in black
sometimes theres a setting for the printer that it sets when theres only a black cartridge try and find a place where it lets you set to print black or black and color normaly thats the problem if not let me know id be glad to help
rate me please
Mar 27, 2009 | Lexmark All-in-One Printer with PictBridge
Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
Jan 03, 2009 | Lexmark All-in-One Printer with PictBridge
Lexmark All-in-One Printer with PictBridge Logo
361 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
