Question about Sewing Machines
Needle won't move on Bernina 930
I am using a Bernina sewing machine and the needle will not move up and down. It will go side to side. It stopped while sewing and won't restart. I have checked all of the common troubleshooting things on the machine and none of them worked. The owner of the machine is on vacation in Ireland, so can't ask her. Help!!!
  • 8 more comments
  • Anonymous Feb 08, 2008
    I have a mechanical Bernina and the zig-zag function won't work. The straight stitch works perfectly. I'm stumped as it ALWAYS worked without a glitch. Wht could the problem be?
    I've adjusted the knobs for width & straight stitch and double-checked the bobbin function, all to no avail.
    The machine is 30 years NEW.
    Colleen
    Colleen
  • Anonymous Feb 21, 2008
    I was sewing and developed a problem with the tension. The stitching was loss on the bottom and I was trying to adjust. The thread broke and I changed the needle and threaded the machine but it would not start back. The needle is locked. I cannot find any broken thread in the mechanism' What do I do.
  • patmck Mar 08, 2008
    Out of the blue at a quilting class , my bernina 930 would not start ! I checked the plugs and the foot pedal. Had to turn the wheel to get it started again !
  • kapuas4 Apr 17, 2008
    My machine, The Bernette Deco 500, is failing to recieve/pick-up the "bobbin" thread. May I get a step-by-step on how to correct this problem?
  • C Marie May 21, 2008
    Our machine was bought in 1975. Allways worked perfectly, my husband used it and now it will not zig zag. Strait only...Thanx...Carol
  • Mesa Mom Aug 25, 2008
    My Bernina 930 is locked. The needle won't move, the bobbin
    won't wind, and nothing happens. I've checked it over, made sure
    the settings were correct, but it simply seems to be locked and won't
    budge. Period. It's not been used for awhile but has been
    covered and protected. It was serviced before it went into
    'storage'.
  • Anonymous Mar 13, 2014
    directions for oiiing bernina 930 sewing machine head
  • Anonymous Mar 17, 2014
    on bernina sewing machine 1630 light switch does not work
  • Anonymous Mar 18, 2014
    i have oile the machine but it will not work
  • Anonymous Mar 23, 2014
    using my bernina 707 and the machine somtimes is unable to pierce the fabric I am sewing thru while working on my binding
My Bernina 930 sewing machine will only do straight stitches when I set it to do zigzag and other decorative stitches
Posted on Aug 15, 2019
If the needle moves when you manually turn the wheel but won't move when you press on the foot control, there's a good chance the problem may be in the foot control. The foot controller parts do wear out. Fortunately, I was able to find instructions on the internet to resolve my Bernina 930 foot control issue. If you are mechanical, you can most likely fix a 930 controller yourself at a very small expense for replacement parts. Otherwise, you might want to buy a new controller.
Posted on Apr 16, 2013
I have had this same problem. Check to see if your bbin is in right. If the bobbin carrier or holder is not in the correct place then the needle nor the wheel will work. Check your manual how to reinsert the bobbin holder and yes, do the oiling.
Let us know what happens as I have this machine also. Love it Have had for 25 years no trouble, would never have another.
Posted on Feb 01, 2008
If the machines motor is running but the needle isn't going up and down then the baste stitch finger is gummed up and needs to be serviced.  This is a simple fix and it happens all the time on those machines.  Take it to your local Bernina dealer for a standard service.  Also if you really need it in a pinch try pushing up on the needle bar that sometimes will fix the problem but it will still need serviced.
Posted on Oct 22, 2007
SOURCE:
My 1630 needle won't move down
Hi Peg.
go to this link and have a read up.when you go to this link if a link opens on the right had side asking you do you want help just close that down and you will be able to see what is being said on what it could be stoping your needle moving.hope this helps.
have Bernina 1630 have been sewing lot the last couple
or you could try this link as well.
sewing machine 1630 needle won move down Google Search
Jun 16, 2018 | Sewing Machines
Bernina 930 Record presser foot lever won't move. On the inside you can see the shaft going up and down but nothing happens to the presser foot. It is currently in the up position but won't go down.
I suspect the machine has seized due to lack of regular oiling. The old oil turns to varnish and acts like glue preventing the parts from moving freely.
CAUTION: your 930 has a basting stitch that will tend to lock up if it is accidentally oiled (or if it hasn't been used for a long time). AVOID applying oil to the middle of the take-up bar (right next to the basting stitch dial behind the case)! A frozen basting stitch is evident when the needle is at its highest point and will not descend.
Wheel on right side that controls the needle up and down is very tight...
Jun 20, 2017 | Bernina Sewing Machines
My bernina 930 speed has basically came to zero. the wheel is turning but the needle is moving very slow and even stops moving even when the wheel is turning. what could be the problem?
Um, how long since the last clean and oil? Sounds like the machine has seized due to old dry oil preventing things from moving. Avoid using the machine until the problem is addressed or the motor may be damaged. (Do this and you will be surprised at how nicely your 930 will run!)
Bernina 930 Record Oil Diagram
am looking for bernina 930 service manual dropped the feed dogs and they...
Mar 17, 2017 | Bernina Sewing Machines
I am looking for a bernina 930 service manual. I dropped the feed dogs and they will not come back up.
Most likely they have seized due to lack of regular oiling. I have used the following method on several older seized Berninas with great success. Just be sure to NOT get any oil near the 930 basting stitch mechanism (about the middle of the needle bar) or it will most likely lock the machine.
This is a diagram for the Bernina 830 Record, but it will give you a good idea of what & where to look for oil ports.
I've never used this source (use at your risk):
Bernina record 930 electronic service manual
Nov 25, 2016 | Bernina Sewing Machines
Bernina 930 change needle position
Look at the knob which creates the zig-zag stitch (1-4) at the top right of your 930. In the center of that is a silver knob that rotates right and left. That silver switch moves the needle position right and left.
Mar 22, 2015 | Bernina Sewing Machines
How can I fix the needle assembly on my Bernina 930 Record...it all of the sudden doesn't move up and down?
There is a screw-in "hub", a round thingie, to tighten on the end of the machine, in the middle of the big spinning wheel. Hold the wheel and turn the hub clock-wise to tighten it ("Righty-Tighty, Lefty-Loosy).
It may be a bit tight to start with, they can "jam" open. Just turn it firmly as needed.
The reason the hub tightens and loosens is so you can run the machine quite fast when filling a bobbin up with thread without having all the gears and werkin's clatter as you do so.
Here is a VIDEO (better than just a photo, yes?) on how to operate your very model sewing machine! https://www.youtube.com/watch?v=drLD66Wa7U0
Aug 04, 2014 | Bernina Sewing Machines
Sewing machine wheel won't turn, motor whirrs
So it sounds like the motor is working but nothing happens? And the hand wheel works ok by hand but nothing when the motor is engaged.
You've broken a belt. I'm not familiar with the 930, but if it has an internal motor... take it in to have it done. It's way too easy to knock these out of time. Spend the extra cash and have it cleaned lubed and adjusted too.
Sep 06, 2012 | Bernina Sewing Machines
Bernina 930 stops with needle down instead of up. How can i fix this?
There is a fairly complex mechanical interlock system on these machines that operate a microswitch on the main power supply board, so that when the needle is at top-dead-centre, the main motor is switched-off and shorted to bring it to a complete halt. Question is, does your 930 always stop with the needle down in exactly the same place or is it just not stopping with the needle up ???
Aug 20, 2012 | Sewing Machines
Bernina 930
Have you ever done a thorough internal oil of your machine? These mechanical machines rely on oil to keep moving but, over time, that oil dries and starts to stick things together. I do a deep internal oil about annually and oil the hook at least every 8 hours of sewing.
There's an oil diagram in this answer:
http://www.fixya.com/support/t26371053-am_looking_bernina_930_service_manual
How do you open bernina 930 sewing machine especially removing the side...
Feb 24, 2018 | Sewing Machines
Sewing Machines Logo
4,229 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
