Question about JVC HX-D7 Shelf System
JVC HX-D7 My sons stereo wont come on anymore- after you push power button it fires up, but then it flashes "status protect" any ideas of how I can get it to work? Jennifer Douglas 918-286-2578
I had a similar problem, and took it to an authorized repair shop(under warranty), the kept it six months, and JVC finally admitted there are solder connections with that model, and six months later, we got a new unit. I will buy Sony next time
Posted on Nov 03, 2007
SOURCE:
When I turn mine on it will power up then go into
faulty spacker m8 spacker may by blow or a wire may be touching and that may be the problem
Mar 17, 2010 | JVC HX-D7 Shelf System
"PROTECT" message in display.
two cables of a speaker were touching each other.
this may be the problem
Dec 29, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
I Have a JVC HX-07 that turns off itself after few seconds showing PROTECT message on display?
the unit may be damp inside.there is dew protection on most new units.It sometimes happens when units are used in the basement.unplug it and plug it back in again and see what happens
Jan 17, 2010 | JVC HX-D7 DVD Compact Stereo Audio / Video...
My jvc hx-d7 radio is turned on in 2 seconds it shuts down to protect mode how do i take protect off ?
You can't. The main amplifier module will probably have a channel blown. The unit is detecting this and tripping into protect mode to stop further damage occurring. Needs to go to a repair place. sorry. ps If you get sound briefly before it trips off then it may just be a speaker wire shorting out! worth checking
Nov 07, 2009 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Protect
The protect message indicates that a problem has been detected in the final output stage of the amplifier. The most common failure parts are the output transistors. Plan on a parts cost between $15-$40. Add in the local labor rate for the total repair cost.
Dan
May 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Protect message
Protect means that a problem was dtected and the output amplifier section has been disabled to prevent further damage. The typical failure parts are the output transistors. Expect a parts cost between $15-$40. Add in the local labor rate for the total repair cost.
Dan
Hx-d7
You have a short in the internal power of this unit. It is going into protect and shutting itself off to keep it from damaging anymore of the internal electronics. Very likely a voltage regulator has gone bad or a power capacitor has gone bad. You will not be able to repair this yourself unless you are skilled in electronic repair. I would suggest contacting the manu and seeing if they have a authorized repair shop in your area. If not ask around and see who is a reputable repair shop in your area.
Feb 08, 2008 | JVC HX-D7 Shelf System
Protect mode
Hi ,
Does your unit go into protect mode without speakers connected?.
Jango
Jan 26, 2008 | JVC HX-D7 Shelf System
"PROTECT" message
I've got a jvc hx-d7 i am working on for a friend, he had it repaired once at a shop with this same problem, they replaced two 42v 2200mf caps. and one A1273 this solved the problem for 8months now its doing it again. I am trying to locate the A1273 to repair it again. Hope this helps.
Dec 25, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
That could meen that something is improperly connected. You should try to disconnect everything, and then reconnect it step by step.
Oct 11, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
JVC HX-D7 Shelf System Logo
166 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
