Question about Toshiba Office Equipment & Supplies
Check the Color Toner Cartridge
When I turned on the Toshiba E3511/4511 copier an error message displayed in the window: 'Check the color toner cartridge' The copier stops there and does not completely start up. I pulled out all the cartridges, shook them a little and placed them back in their slots (did this about 4 times). I turned off the copier, waited 10 seconds then restarted it. Still the same message came up. Suggestions PLEASE? Thank You Very Much.... Busy Doctors Office in PA.
  • Toshiba Master
  • 653 Answers
Try to take out all the color toner.. And start the machine... If machine can startup properly, it will ask u to insert toner one by one...
PS: What is your current print counter?
Posted on Apr 17, 2009
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
My Toshiba estudio 4511 says call service
Your CYAN is one of 3 colors the "Smart guys" came up with to make 252 some colors. Between Cyan Magenta Yellow and the ever so present Black you can make all your colors. Obviously you don't need the three C,M,Y to make a black and white copy. So the issue remains that a low or empty Cyan (pronounced S-eye-ann)
A couple differant issues I've run into since the creation of color copies near 2003 is A pull tab on the toner isn't pulled off before inserting the tube. Another is for several possible reasons the toner just isn't getting down into the developer mixing auger. There is also, upon occasion a situation that the motor that turns the toner auger inside the new toner cartridge doesn't turn enough/properly/ or at all. These days that will almost always throw a code in the display window. My 23years of Toshiba tells me try your C cartridge, play with it a bit and make sure its in right, with tab pulled. another tool is monitoring how long it tries to and the Cyan, does it attempt to restore it' levels for about 90 seconds or is it immediately tell you there's a cyan issue? Can you hear the motor and toner bottle turning? It should tell you "adding Cyan Toner" or even "Check Cyan Cartridge" worst case scenario you call Toshiba business Solutions and they vacuum it all out and do some adjustments......could be a good thing With Toshiba you get a lot of bang for your buck, meaning: a service call is good every once in a while. Your 4511 is a work horse you won't regret $pending for service. ~~~~~> SC
Sep 22, 2014 | Toshiba Estudio 4511 Color Printer,...
How can i settle the problem of magenta developer finishing so fast. Magenter developer for Konica Minolta Bizhub C550 is getting finished so fast.
If the message Change Imaging Unit Magenta displayed refer to imaging unit with contents a developer.The Imaging unit life is 80.000 copies.
The imaging units located after front door when is located the waste toner box.
If the message M toner end/change the M toner displayed refer to toner cartridge
The toner cartridge life 15.000 copies 5% saturation.In full color mode the color saturation is 80% and the color toner life is 6.000-8.000 copies.
I think your problems is a toner not the developer.
Apr 11, 2013 | Konica Minolta Bizhub C550
Error code sc 680
Refer to BCU/MUSIC communication error.After the engine CPU sends a message,the MUSIC CPU does not respond within five seconds three consecutive times.
Possible cause:toner cartridge memory chip loose connection,memory chip problem,memory chip cable wiring problem.
Turn the main switch OFF/ON.Check if the toner cartridge is installed correctly,replace the toner cartridge,check the harnessess are not damage or replace BCU board.
Feb 14, 2013 | Ricoh Aficio 2232C Color Copier
Error code cf30 in toshiba 3511 what its mean and how can fix it
(CF30) - Reference plate detection voltage abnormality: The output
value of the color auto-toner sensor against the reference plate
is out of a specified range at the light amount correction during
an auto-toner adjustment or when a print job has finished.
Your color auto-toner sensor and reference plate are located under the input tray cover on the left side of the copier when you are facing it. It is on a bracket that hangs down into the copier and sits close to the revolver inside the machine. It is an optical sensor and if either it or the reference plate get stained with toner it will give you this error message, you may attempt to clean them with rubbing alcohol.
This error message may also occur if the solenoid that drives the reference plate is faulty so you will need to check that as well.
I would sincerely recommend that you get an authorized toshiba technician to take a look at the machine for you as this is a fairly difficult problem to fix right.
Sep 29, 2010 | Toshiba E-Studio 3511 Color Copier
Our imagistics 8130 has the replace waste toner bottle error message on but the waste bottle is empty and I turned a wheel above the waste toner bottle and nothing.
Hi how are you this is jack ... jack_pak@hotmail.com
Dear you wash the waste toner bottle clearly. But error still your copier you check the waste toner bottle dection SENCER OR IS DIRTY CLEAN IT..
PLEASE VOTE ME .
Thanks
Best Regards,
Aug 14, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Toner Problem
Check the carriage that the color toner sits in, make sure that it is able to rotate. Also, make sure there's toner in the catridges, and that there isn't toner on the sensors.
Apr 17, 2009 | Office Equipment & Supplies
179 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
