Question about DeLonghi MW 605 Convection/Microwave Oven
It turns on ...lights up but doesnot heat or warm the food
I HAVE DELONGHI ED8525S-SBD MICROWAVE IT TURNS ON... LIGHTS UP BUT DOESNOT HEAT FOOD ..ANY ADVICE
  • 3,037 Answers
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
Does not heat up
Check this video it goes through checking and replacing magnetron, capacitor, diode and fuse. It will be one of those. Check the safety instructions in the description.
Aug 10, 2014 | DeLonghi Microwave Ovens
My micro/oven/grill (ed8525s-sbd on rear) will not turn on. after using the oven feature around 20 seconds after it had done it tripped the kitchen sockets and set the house alarm off. the fuse in the plug...
It's likely that some part of the microwave has gone short circuit and blown the main fuse. The fuse is a 7000 volt glass encapsulated inline fuse housed inside a tubular plastic case about 2 inches long.
Renew the fuse and switch on. Look out for anything that is not functioning and replace that part, eg, fan, light, turntable motor etc.
Jan 29, 2014 | DeLonghi MW 605 Convection/Microwave Oven
Microwave delonghi
Check input power board and fuse.
Dec 01, 2017 | Microwave Ovens
Hi, i have an ac925efy delonghi microwave oven, i bought it manufacturer refurbished and when i switched it on there was a big bang and a flash. it came from what looked to be the back top right hand...
From your description it is the magnetron that heats the food that has gone, I suggest that you take it back for a refund, because if you decide to fix it the repairs will run you more than what the microwave oven is worth.
Jan 16, 2011 | DeLonghi MW 535 Microwave Oven
Where can I get user manual for Delonghi Touch control microwave oven ED8525S-SBD
You can download the complete instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 23, 2010 | DeLonghi MW 605 Convection/Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
I have been given a DeLonghi 850 Microwave but have no instructions - is it possible to get some. It has a serial number of ED8525S-SBD. I tried to heat something but it wouldn't think I must be using the...
try looking for your manual here: http://www.delonghiusa.com/index.php?texts&pid=10
If you can not find it, try calling their customer service, and ask them to send you a manual!
help@delonghi-csservice.com
1 (800) 322-3848
Sep 09, 2009 | DeLonghi Microwave Ovens
Replacing a bulb on delonghi combi oven ED8525S-SBD
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Nov 24, 2008 | Neff H7871 Convection/Microwave Oven
DeLonghi MW 605 Convection/Microwave Oven Logo
911 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
