Question about RTO Bicycling Complete Guide to Bicycle Maintenance & Repair
Having problems with gears on my Apollo LSX 1.1 mountain bike
The gear shift lever on the right hand side of the handle bars doesn't work at all when trying to move up the range but did to move down the range (kind of). And the gears (1,2,3) on the left hand side of the handle bars only gets the first two ( I think it may be the derailure partly to blame as it rubs on the chain incertain gears). Also the crank has just spun a couple of times with no forward motion happening until I change the left hand gears then it re-engages. The crank also seems to have a grinding feel to it. Can you also tell me how to raise the handle bars, I've tried to do this myself and undid the allen/hex bolt but could not get it to move up. Thanks in advance for any tips, Dean...
  • 1 more comment
  • Anonymous Apr 17, 2009
    I dont know how to raise the handle bars of my mountain bike
  • pulse_of_the Apr 18, 2009
    Thanks dude. I like to learn how to do things myself as a rule!
  • Anonymous Mar 22, 2014
    changing it up and down,the friction bar no use
    Problem Solver:
  • 15 Answers
Sounds a lot like cable stretch. Have a local bike shop replace all the cables and do a derailleur adjustment. Costs is usually under $40 complete.
Posted on Apr 17, 2009
  • Louis Newton Apr 18, 2009
    To raise the handlebars loose the two binder bolts on each side of the stem mount so that the handlebars rotate left/right without much effort. Then loose the stem bolt located in the center top of the stem. Pull up with moderate pressure (or push down if the reverse is needed) while gently rotating the bars left/right to the desired height. Center the bars and retighten the stem bolt to firm snug, but not over tightened, then retighten the two binder bolts. Of course, if your handlebars are of a different configuration, this may not work as described. Additionally, it is possible that they have seized a bit from exposure to moisture, dirt, etc.
  • Louis Newton Apr 19, 2009
    You might try Sheldon Brown's bike fixit site for other ideas.
What is a derailler
A derailleur is a device that assists in shifting the gears and moving the chain from one chain ring to the next. This is generally achieved by the use of a cable and a shift lever that is attached to the handle bars.
Jul 11, 2014 | Shimano Brake Cables Atb Mountain Bike...
I have a Huffy Verona 18 speed with the Soleus shifter first the cable wasn't working so I put wd-40 down the cable that has freed it up but I'm having problems getting the rear railer to change...
When I have had that trouble with my own bike, I have taken the cable off and replaced the vinyl housing. If that isn't an option, get the cable as free as you can, then lubricate the rear derailer, and with a cloth, so as not to soil your hands, grab hold of the derailer and work it back and forth to free it up. Riding the bike causes all the road grime to accumulate on the derailer making it stick.
Hope this is of some help
Joe
Aug 30, 2011 | Cycling
Dymacraft Mod 8575-83D How do handel bar gear shift operators work. Both of them are defective (will not shift gears) and I would like to know what is inside the handle bar gear change mechanism before I...
Before you go and disassemble them and make things worse, get a grip (pun intended) on the derailleur adjustments.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Search engines can instantly answer high level questions like "how things work", usually with videos.
While you're at it, search for "how to shift a mountain bike".
Jun 16, 2011 | Dynacraft Cycling
There are gear shifts on both handle bars (diamondback cobra 24). How do I instruct my 10 year old how to shift the gears? which is easiest setting and hardest setting?
I strongly suggest taking the bike and your son into a bike shop. They will be happy to show him not only how to shift the gears, but why and when. Also they may even throw in some maintenance tips.
The easiest settings will be labeled 1 and the hardest the larger number. if you were too look at the bike where the chain is, the gears that are closest to the frame are the easiest and the ones far away are the hardest. In the back this means the largest gears are the easiest in the front they are opposite, smallest gears are the easiest.
There are a number of good books and many free instructional videos on youtube that show shifting principles. The biggest issue for 10 year olds is whether they can reach the levers comfortably.
Apr 23, 2011 | Diamondback Cobra 24 Mountain Bike Boys' ...
I have an old Avanti Edge Cro-Mo bike. I know the brakes are on the right handle bar but not sure how to upshift and downshift gears.
If this is the road bike model, then most likely the shifter and brake lever are the same. To brake pull back on the lever, to shift move the lever toward the center of the bike.
The Right lever works the REAR gearing. This makes small changes. The bigger lever will shift the gears toward a larger gear and make the cycling easier. The small lever works the opposite.
The Left lever works the FRONT gearing. This makes large changes. The Bigger lever will shift the gears toward a larger gear and makes the cycling harder. The small lever works the opposite.
If you don't have these types of levers, I can give you different instructions but the essentials of big lever/ small lever and Right/ Left are the same.
Nov 25, 2010 | Cycling
First time driving a 1967 Triumph motorcycle coming up. Would like advice on where stuff is like clutch, brake, shifter and how to shift -- where the gears are. Thanks. Art asanfelici@verizon.net
Hi Art! First of all, congratulations on your 1967 Triumph... that's a beauty!!!
Basic things to know before riding a bike is it's parts.
Clutch is the lever you press on the left side of the handle bar.
Front disc brake is the lever on the right side of the handle bar.
Shifter is the one you're stepping on when shifting gears and is located on the left side of the engine if you're on it.
Now, you must first know if the gear is on Neutral by pushing the bike before starting the bike. If it's hard to push then the shifter is not in neutral. Press the shifter by your left foot until you are able to push the bike with ease.
Hop on the bike and start the engine. Most bikes have ignition starters but if your bike doesn't have one, then you have to turn keys to on position and use the kick starter. Rev the engine by pressing the throttle grip on the right side of the handle bar.
Engine is running and in idle position. Press the Clutch lever (left hand) and press the shifter once (left foot) DO NOT RELEASE THE CLUTCH YET!!!
Slowly press the throttle with your right hand until you hear or feel the engine purr...
Slowly release the clutch (left hand) until you fell the bike move forward.
If I am not mistaken, shifting the gears of the triumph is 1-down and 4 up...
Every time you shift gears, you need to press the clutch to release the gears.
Hope you'll have fun!!!
Ride safe my friend!!!
Don't forget your riding gears!!!
^_^
Jun 22, 2010 | 1993 Triumph Tiger
Bike gears
usually there are 2 levers on each handle bar, one lever lowers the gear while the other one raises the gear. usually the right handle bar has the shift for the gears on the rear wheel, while the left handle bar has the shift for the pedal gears
Oct 08, 2009 | Cycling
The gears will not shift on the right handle or the left properly
There are good instructions here under front and rear derailleur adjustments:http://www.parktool.com/repair/byregion.asp?catid=53 This is my favourite site:http://sheldonbrown.com/gearing/index.html Hope this helps.
Aug 11, 2009 | Mountain Bike Bmx Fit Gt Haro Chrome...
RTO Bicycling Complete Guide to Bicycle Maintenance & Repair Logo
481 people viewed this question
Top RTO Cycling Experts
John Egan
John Egan
Are you a RTO Cycling Expert? Answer questions, earn points and help others
