Toner Problem when I turned on the Toshiba E3511/4511 copier an error message displayed in the window: 'Check the color toner cartridge' The copier stops there and does not completely start up. I pulled out all the cartridges, shook them a little and placed them back in their slots (did this about 4 times). I turned off the copier, waited 10 seconds then restarted it. Still the same message came up. Suggestions PLEASE? Thank You Very Much.... Busy Doctors Office in PA.
    Problem Solver:
  • 7 Answers
Check the carriage that the color toner sits in, make sure that it is able to rotate. Also, make sure there's toner in the catridges, and that there isn't toner on the sensors.
Posted on Apr 17, 2009
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
F2-40 ERROR
I am assuming your copier is a mono copier only & not full colour, if this is so then the error code refers to a toner supply fault. If you remove the toner cartridge & gently shake it side to side, turn the machine off & then on, refit the toner cartridge & check to see if the machine has reset. If the error is displayed again you may have to replace the toner cartridge with a new one. Again, powering the machine off & on should reset the error message.
Hope this helps.
Aug 13, 2014 | Sharp Office Equipment & Supplies
Error code sc 680
Refer to BCU/MUSIC communication error.After the engine CPU sends a message,the MUSIC CPU does not respond within five seconds three consecutive times.
Possible cause:toner cartridge memory chip loose connection,memory chip problem,memory chip cable wiring problem.
Turn the main switch OFF/ON.Check if the toner cartridge is installed correctly,replace the toner cartridge,check the harnessess are not damage or replace BCU board.
Feb 14, 2013 | Ricoh Aficio 2232C Color Copier
I have a problem with toshiba e studio 181: i've changed a new toner cartridge but the indicator of toner is still flashing, and the machine didn't give any acces.
first check if the cartridge is original usually "have a serial & par code"
& Shake it will & clean carefully the green ship at the end off cartridge
check if the cartridge is already opened
turn the cartridge upside down " open the wight square tab & turn the Shield the Opposite Hand
[ check if broken ] while turning it .. you must see tone Flipping or moving at the square tab window
if not that's mean shield broken
try to fill its toner to an empty cartridge..
Jul 06, 2011 | Toshiba 1360 Black and White Copier
Toner sensor error
Hi
This error comes up when the printer detects that the toner of particular color is missing. This indicated that the indicated color toner is missing from the printer(eg-- C = Cyan, Y = Yellow, M = Magenta, K = Black).
C5150 may face a toner sensor error after installing used sets of toner cartridges and sometimes even after installing new toner cartridges as well. This error can be bypassed. This can be disabled by following these steps---
1. Turn machine on while pushing and holding the (+/-), menu buttons at same time.
2. Menu window will show OKI USER.
3. Scroll to Engine Dialog Mode is indicated Push Enter button.
4. Diagnostic Mode xx xx xx S Mode is indicated.
5. ( = 2 ) . Press (- or +) button until “ENGINE - PARAMETER SET =2” is displayed.
6. Push Enter button.
7. TONER SENSOR - ENABLE is displayed.
8. Push Enter button.
9. Press (- / +) TONER SENSOR = DISABLE is displayed.
10. Press ON LINE CANCEL buttons at same time.
11. (*) is displayed.
12. Restart the Printer.
Daniel Scott
Jun 22, 2010 | OKI C5150n Led Printer
Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Check the Color Toner Cartridge
Try to take out all the color toner.. And start the machine... If machine can startup properly, it will ask u to insert toner one by one...
PS: What is your current print counter?
Apr 17, 2009 | Toshiba Office Equipment & Supplies
I CHANGE THE CARTRIDGE OF THE COPIER AND TURN ON IT. SO THE COPIER DISPLAY MESSAGE 2F.
i think the error your actually getting is F2. this error pertains to toner cartridge chip error. it's that little chip on at the end of the cartridge.you'll need to have that replaced.
Mar 25, 2009 | Sharp AR-M160 Laser Printer
k24674
jasbo
jasbo
