Question about NEC ND-3550A DVD±RW Dual Layer Burner
Can't burn The DVD drive can read CD and DVD, but cant burn. The drive is _NEC DVD_RW ND-3550A
  • buffalonyman
    buffalonyman May 11, 2010
    What burning software are you using?
5 Suggested Answers
fire sine
  • 382 Answers
SOURCE: NEC DVD+RW ND-1100A
This is a single layer drive only. Usually dual layer drives have DL in the form factor so possibly a
NEC DVD+RW DL?
http://www.adamant.com/itemInfo.asp?GotoID=ITEM&PrdAbr=CDVN-3540A&menu=PARTS
Posted on Oct 24, 2007
  • 262 Answers
SOURCE: NEC ND-6650A
well, sounds like common error promblem have you tried looking and seeing if mite have bought the wrong kind of dvd's I have done this before i bought dvd's instead of Cdrw's discs.? or try dowloading www.slysoft.com thier cd player plays and reads and rewrites almost anything .. lala linda
Posted on Jun 03, 2008
kikoksky
  • 119 Answers
SOURCE: NEC ND-3550A won't read discs
try this Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the Upper/lower Filters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value? The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
do same thing to erase the lower filter then restart your computer
Posted on Jul 24, 2008
  • 46 Answers
SOURCE: i have problems with my nec nd-3550A dvd rw
Make sure that your buner supports the type of blank DVD that you are using.
Posted on Jan 24, 2009
I got a message said your nec dvd_rw nd 3550a is corrupted (code 39)
Try re-installing the drivers.
or You can try this automated fix from microsoft.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Read and follow the instructions.
Good Luck
Nov 10, 2010 | NEC ND-3550A DVD RW Dual Layer Burner
I have nec dvd_rw nd-3520a on my computer it will not play dvd ram is there something i can download to facilitate this?
fraid not , these are the only dvd formats this drive supports
DVD-ROM • DVD-Video • Multi-Session • DVD-9 • DVD+R • DVD-R • DVD+RW • DVD-RW
dont try to flash the drive
Oct 07, 2009 | NEC ND-3550A DVD±RW Dual Layer Burner
My desktop is not playing cd or dvd's.
go to control panel and search for new hardware...or download new firmware fpr your device
Sep 29, 2009 | NEC ND-3550A DVD±RW Dual Layer Burner
Problem with NEC DVD
Cd's use a different file structure that dvd's. Dvd's use udf and cd's use cdfs. Try cleaning the drive with a cleaning cd and downloading the latest drivers for the drive from the NEC website for the easiest fix.
Aug 30, 2009 | NEC ND-3550A-KIT DVD±RW Burner
My nec 3550a wont pickup a burnt dual layer disc
It may not be compatible with a dual layer disk, just the regular dvd-r or dvd-rw disks.
Jul 19, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
Have NEC 3550A DVD/rw. re-installed windows XP professional & all else.. DVD will not recognize most dvd discs.Got drivers from NEC.. still problem
Go to:
1. start > run > devmgmt.msc
2. Under DVD/CD Rom drives make sure it's installed (Uninstalled = Yellow icon)
If all drivers are applied correctly this could be a problem with the DVD Region Settings.
Go to:
2. expand
3. find the device
4. right click > properties
5. go to dvd region tab
6. select the desired region
Warning: some drives only allow you to change it up to 5 or 4 times so be careful!
Jun 23, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
I have problems with my nec nd-3550A dvd rw
Jan 24, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
Dvd writer
run filtercheck 4.6 or some tool to remove upper and lower filters.
Aug 18, 2008 | NEC ND-3550A DVD RW Dual Layer Burner
Can't read dvd
club.cdfreaks.com firmware update
Mar 16, 2008 | NEC ND-3550A-KIT DVD±RW Burner
DVD Drive Problem
one easy test to do is use a bootable cd and boot from cd instead of windows. if it boots its an issue in windows. if it don't boot its likely bad hardware.. i have exact same model drive for over a year
a good boot cd easy to get is a memory tester www.memtest.org the zip file has an iso i burn with imgburn.com tool
Nov 03, 2007 | NEC ND-3550A-KIT DVD±RW Burner
NEC ND-3550A DVD±RW Dual Layer Burner Logo
143 people viewed this question
Top NEC Computers & Internet Experts
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
