Want to program a standard ecu car to a modify one .
Any short courses that you can take for you to learn how to reprogram an ecu for any car
    Brigadier General:
  • 5,158 Answers
Perhaps start here on your learning experience.
http://forums.openecu.org/index.php
good luck
robert
please take a moment to rate this solution
Posted on Apr 17, 2009
Reprograming replaced ECU
Do they need reprograming, dont they come ready to install. I have never pre programed one. Only programed after installed in vehicle to change power curve or fuel settings not really sure what you mean
Mar 30, 2014 | 2011 Nissan Rogue
Is there a way to reprogram the ECU
You can't do this at home it requires very expensive equipment if it can be done at all, that all makes can be programmed.
Sep 25, 2012 | Cars & Trucks
What is ECU and how to make the ECU programmer? How exactly is that work
Electronic Control Unit, An engine control unit (ECU), most commonly called the powertrain control module (PCM), is a type of electronic control unit that controls a series of actuators on an internal combustion engine to ensure the optimum running. It does this by reading values from a multitude of sensors within the engine bay, interpreting the data using multidimensional performance maps (called Look-up tables), and adjusting the engine actuators accordingly.
Automotive ECU is to convert stored procedures chip in simple, replace the programmed chip, as long as open the backplane of the ECU and unplug the original chip and then put the new chip , as some older E-ROM chip only can write just one time, every time you modify the program you must turn the program of original chip into a blank chip and then replace the original chip. If you want to have a program modified by yourself, you need a ecu programmer.
May 12, 2012 | Cars & Trucks
My jetta tdi has high deisel consumption. why ?
WHEN EVER YOU DISCONNECT BATTERY PCM LOSE MEMORY WHICH CAUSE POOR ENGINE PERFORMANCE.TAKE CAR TO VOLKSWAGON DEALERSHIP LET THEM REPROGRAM IT.
May 25, 2010 | 2000 Volkswagen Jetta TDI
Please describe your is there a preformance chip in my 1993 chevy k1500 4x4 and if so where and how much do they cost i was told there was one and it would raise the rpm before shifting and could get me...
Yes there is a performance chip.. Its in the ECU,, its what controls the air fuel ratio, and other things.. Modifying the chips programming will increase performance,, as well as fuel consumption. There are 2 ways to modify this..
1.) purchase a pre modded ecu and switch it with yours..
2.) A mechanic can reprogram the ECU with the modified programming..
In eighter case you will need to find a mechanic who specializes in customization and modification. I'm sure there is one in your area or atleast someone who knows of one..
I strongly suggest you dont attemp the mods yourself because it can damage the ecu, engine , transmission and really mess things up if you make any mistakes..
The modification is done with a diagnostic tool which is capable of reprogramming the EProm in the ECU. The Mechanic will already have the modified firmware for the device,, which he will then burn onto the eprom..
Mar 20, 2010 | Chevrolet 1500 Cars & Trucks
Replaced the ecm computer on 2001 dodge durango then start it up and it runs and then cuts itself off after 15 seconds
The ECU would have to be programmed from the dealer. It normally costs somewhere around $100 to have it reprogrammed. The reason it needs reprogrammed is because the factory theft module in your car is different than the theft module in the car that the "new" ECU came from. I had this problem with my 1997 Cadillac Deville.
All you would have to do is get it to a Dodge dealership and have them reprogram the ECU. Make sure you explain that you just replaced the ECU, and you need it reprogrammed to match your SUV.
Please vote on my solution whether good or bad. Thanks! :D
Oct 25, 2009 | 1999 Dodge Durango
Installed new steering column, computer reprogram.
I dont dont think so it should have been compatible first or you would have lights on/ thats just another 110.00 for them to program it/ Thanks for using fix ya Please rate my response thank you very much
Jan 30, 2009 | 1994 Buick LeSabre
127 people viewed this question
jasbo
jasbo
