Question about LG AX8600 Cellular Phone
LG AX8600 phone is broken in half..need flex cable for bottom
THE FLEX CABLE APPEARED TO BE CONNECTED TO THE MAIN BOARD ON THE LOWER PART OF PHONE..THE SCREEN IS NOT CRACKED ITS JUST THE CABLE..I thought id be able to fix myself until i ran into this problem...please help ...i need phone contacts off phone and i didnt have a memory card in phone...thank you
    Problem Solver:
  • 7 Answers
You should be able to take it to Alltel or Verizon and they can pull the information out of it possibly. If screen works, you can go to the apps and use mighty backup(call representative for instructions).
Posted on Jun 19, 2009
My droid phone screen just went black, i wasnt in a phone call or anything, what do i do? i tried taking out that battery it doesnt work at all.
I am sorry my friend but sad to say that you will need to bring it to a service center, the possible cause is your FLEX cable or tape cable connected to your main board all the way to your LCD screen, it need to be replaced.
Aug 25, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
There is a problem while fliping the mobile is display will became white
your flex was damage..
you need to replace the flex..
what is flex?? (flex is the ribbon cable that connected between lcd area board to main board.).
or try to dismantle your phone,and check if there is any disalignment or loose contact...use t6 screw driver..
Jun 17, 2010 | Nokia 5300 Grey Cellular Phone
Volume buttons won't work, camera button wont work, and speakerphonew button wont work. Happened out of nowhere. Cannot lower/raise volume on side of phone, only vibrate works.
Hello.
Welcome to Fixya's Community.
These problems HAve been related to a damaged flex cable.
This is the cable which in the U700 connect the lower part of the phone to the lcd part (with the screen, speaker, camera and touchscreen buttons). All the data such as screen images, camera pictures, speaker sounds pass through this cable from the main board which is located in the lower part of the phone.
Unfortunately, each time one opens the phone, the cable slides between the two part of the phone. In the long term, as the cable is thin and soft and this movement causes frictions between the cable and the parts, the cable consumes itself. the damage of the cable could results in weird effects on the phone.
In order to fix that you need to replace that part.
its easy.
just take the phone apart and locate the flex cable and replace it.
believe me you can do it yourself.
  • The Flex cable of your phone cost 3 $
  • A phone repair shop will fix that for 25 $
see if you can find it on eBay.
remember its SCH-U700 Not SGH-U700 there is a big difference.
Additional Help:
Learn more about Flex Cables.
Good Luck
Nov 10, 2009 | Samsung Gleam (SCH-u700) Cellular Phone
My screen split in to two idenical screens
dismantle your phone and clean the contacts of the main board and the ribbon/flex cable,contacts of lcd to ribbon/flex.if it doesnt work.change the flex.
May 11, 2009 | AT&T LG CU720 Cell Phone - Silver
Lg rumor flex cable
go to a corporate repair store, its a known issue, replace for free, takes about 10, min
Jan 03, 2009 | LG RUMOR Cellular Phone
I can't hear anyone but they can hear me. Also, the ring on the phone never makes that burr noise to i never know if i have connected to the line Please help thanks
Your phone's Flex cable or speaker is bad. I would bet on the flex cable being the culprit. LG VX 8500/Chocolate has a BAD rep for it's flex cable being inferior. Very common problem for the VX 8500....they fixed that really fast with its replacement, the VX 8550.
Jun 06, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Help
you may have a faulty phone ...needs to be returned...the flex cable in the screen is damaged or loose.does the screen come on at all?
if it does that means your screen flex cable is faulty and if it doesn't your main flex cable is loose maybe from a fall or water damage.This needs to be handled by a qualified service tech. to get to the main flex cable the screen cover would have to be removed via the four screws located under the 4 rubber stubs on the main inner screen.You need to have a t6 otr a t4 screw driver to remove the cover.the main flex cable pops right off but the ear piece flex cable is a little more difficult.thanks !
sam !
May 12, 2008 | Motorola Mobility RAZR V3
BLANK
the problem of your phone is the flex cable, just go to your nearest repair phone shop if they have a spare of flex cable for your phone.
peace!
Nov 27, 2007 | LG PM-225 Cellular Phone
Broken LCD repair
Boss this is not an easy job. To replace the LCD u will have to separate the top portion from the other. I would suggest take it to a reliable technician and he will do the job for u.
There is a flex cable that is connected to the main board through the hinges of the phone and even if u manage to separate the two care should be taken while fixing it again as the new flex (that comes with the LCD display) may get jammed if wrongly done. Only an expert will help u here
Nov 04, 2007 | LG VX8300 Cellular Phone
Flex cable
It's fairly simple to replace a flex cable if that's the culprit. This is a flex cable: http://cnn.cn/shop/motorola-razr-keyboard-flex-cable-p-300.html It's got adhesive on it so if you plan on repairing yours, you need to peal your old one off. That's really no big deal, the thing you REALLY need to worry about is damaging your keypad when removing it from your housing. You might want to order a new one just incase for that very reason. Be aware that unlike the V3c's flex cable which is a separate cable that connects to the main board to go up to the upper part of the phone, the V3's keyboard flex has its cable attached, which means you must open the top portion of your phone as well. Opening the bottom part of the phone is simple. Opening the top part is where things get slightly tricky, if you're not careful you could really damage your phone.
May 14, 2007 | Motorola Mobility RAZR V3
LG AX8600 Cellular Phone Logo
168 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
