Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
NEED A FUEL LINE DIAGRAM FOR POULAN 2250 2.2 C.I 16 INCH BLADE
  • Anonymous Mar 13, 2014
    diagram for fuel & bulb & hook up to calibrator for model 2250le
The smaller size line comes out of the tank, leave enough to install filter on that line in the tank, this line goes to the intake side( I think it is the right side of the carb when it's mounted in the saw), of the carb. The other smaller line goes from the other side of the carb to the primer bulb. The larger line goes from the other side of the primer bulb back to the tank, it only has to be pushed in the tank about 1/2 to 3/4 inch. The large line goes in the tank in the hole on the right side unde the carb. The primer bulb has different size nipples. I just put these on mine, it's hard to get the lines in the tank, I sprayed mine w/wd40 and just pushed them in until I could pull it with some needle nose pliers or hemostats.
Posted on Apr 29, 2009
Weedeater wt3100 carb and fuel line diagram
motor will start after several pulls but will only run for about 10 seconds,
Nov 01, 2012 | Poulan Pro 952711635 String Trimmer Line...
My fuel lines all broke and fell apart, I need a fuel line diagram
Hi chuck belew...
Check out the diagram below.
I believe this is what your looking for.
Please take time to rate me
Bud
Oct 11, 2012 | Poulan Pro PP3416 16-Inch 34CC Gas...
Do you have a diagram for how to install a deck blade for a poulan 15.5 hp 38" 5 speed briggs and stratton
If you are refering to the actual blade and not the entire hub assembly then it is real easy. Just take out the one bolt in the middle of the blade and put your new blade in.
May 04, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a small poulan micro chainsaw with a walbro wa19
I am going to close this. We can continue to converse as we have.
I present you with these parting gifts (look at the 1800 and 2000s):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Just in case
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Good Luck.
Lou
Feb 25, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
How do I hook up a fuel line to a carbuertor on a Poulan 18 inch?
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/thumbs/Lou98321/fuelsystem.jpg
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
Poulan.com
The dash number of your serial number is the type. HTH
Lou
Dec 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need the fuel line routing or diagram for a Poulan Predator 2150 LE. I have parts list but it does not depict the fuel detail I need.
Jimmy there are no Poulan drawings with fuel system detail worth the ink it takes to print them, but that is all there is.
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb (once compressed bulb draws fuel as it returns to normal) , bulb (as it is compressed) returns displaced to fuel tank. HTH
Lou
Oct 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Gas line
What little fuel system detail ther is can be found here:
Poulan.com
Find a model number that matches your saw.
Fuel lines run from the tank to the carburetor to the purge pump and back to the tank. Take extensive notes and a few digital photos as you go are a good idea.
SmallEng.com
HTH
Lou
Oct 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to put deck belt on
need a diagram of how to put a deck belt on a 15.5 hp/38" cut 5 speed poulan lawn mower model number 9601200-3801
Jun 22, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
2,286 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
