Question about HP Office Equipment & Supplies
I have a hp1310 how do i find my ink leval - HP Office Equipment & Supplies
  • 385 Answers
In the HP Director software, click Settings , move your mouse cursor over Print Settings , and then click Printer Toolbox . The Printer Toolbox opens. Click the Estimate of Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining. Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Hope this helps Regards
Posted on Apr 17, 2009
Have Sterling model RF-45-NG, with Honeywell gas regulator SV9500 that will not start. Getting 6 flashes as code. Fans start, ignitor starts.
Clean flame senser first , try jumping out pressure switch , or try jumping out hi leval cut off or low leval cut off , could be air in gas line .
Sep 02, 2011 | Sterling RF45 Propane Gas Heater (45,000...
My Lexmark printer 1270 only prints in black and white although the colour cartriges have good ink levals. This has just started happening, it was happily printing in colour not long ago. Many thanks.
Jast go to print option. Then Mantainance. Then try to print a nozzale. If all the colour comes out properly ( with out dot or misline), your cartrige head is goog for print. If not, your printer cartrige head is block. To reque from the problem follow the proces:
1. Unpluge colour cartrige.
2. Try to clean the cartrige head with soft cloth and amonia gentaly.
3. Try to out the ink through the head nozzale pore by using shaking or gentaly swape by soft tissue.
4. Now put the cratrige head upon a soft tissue. ( ink will comes out). If not, repit stage 1-4 until ink come out.
Thank you
Jun 07, 2011 | Lexmark X1270 All-In-One InkJet Printer
Need to check transmission oil level two pugs on side of gearbox is the lower one the level and the higher one the filler
the lower is the drain the upper is the fill and leval check if u can touch fluid or it runs out of upper your leval is good
Oct 05, 2009 | 2004 Mazda RX-8
How do i find ink leval
what type of printer - check under ...start-control panel-printers and faxes-(select your printer...click) - printer - properties - maintenance - you can reset here if you have the full driver installed for your printer
Apr 15, 2009 | Office Equipment & Supplies
Transmission slow to start
the trasmission fluid leval may be low or your cluches are slipping. check the trasmission fluid leval with the engan wormed up and the trasmition in park pull the dip stike with yellow on it and check the level alsow smell the dip stick if it smells burnt the the tran fluid need to be changed.
if it is low put tranmition fluid in it by using a long funal and put the fluid in the tranmition dip stike tube. If the leval is full and the fulid is not burnt it might be trasnmiton cluches and the tranmition needs to be rebilt.
Feb 24, 2009 | 1993 Chevrolet C1500
My HP1310 all in one fails to recognise the color ink cartridge. It says insert ink cartridge. We havwetried reinserting the ctg turning it onn and off , puulling the power plug etc. All get the same...
I am assuming you are using hp 27 and hp 28 ink cartrridges.
Try this:
1. use a eraser, and erased the circuit at the back of the cartridge. (Clean the oxidation of the circuit -- retry). Note that circuit on these cartridges can go bad.
2. If 1 does not work., try another cartridge that you know is good and if still fail you have a printer problem
Most probably you have a bad cartridge.
Oct 12, 2008 | HP Office Equipment & Supplies
No printing
If you brought new Lexmark cartridges please change it as it comes with one year warranty but before try to perform a self test, (i.e make a copy) if it works then try printing , if get the error then change the cart.........................
May 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP1310
Try to reinstall the driver
Jan 19, 2008 | HP PSC 1315 All-In-One InkJet Printer
Keeps saying to replace cartidge
you have to go int the ink leval thing i think and tell it you installed a new ink cartrige that should fix it
Dec 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
55 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
