Question about Kitchen Appliances - Others
Delonghi dante - heta keeps cutting out and blowing cool air rather than warm
WE HAVE A DELONGHI DANTE WALL MOUNTED FIRE WHICH WE HAVE HAD FOR A COUPLE OF YEARS. YOU CLICK ONCE ON THE REMOTE TO SWITCH ON THE FLAME - BUT WITH NO HEAT, THEN CLICK ONCE OR TWICE FOR THE LOW HEAT OR HIGH HEAT CONTROL. WHEN WE HAVE THE HEAT GOING FOR A BIT - WITHOUT US NOTICING IT HAS TURNED TO COLD AIR RATHER THAN WARM. WHAT COULD THIS BE - WE HAVE ONLY JUST RECENTLY STARTED NOTICING THIS HAPPENING - THERE IS A LITLLE DIAL ON THE BACK OF THE REMOTE WITH VARIOUS LETTERS AND NUMBERS ROUND IT COULD IT HAVE BEEN SWITCHED TO THE WRONG SELECTION? - WE HAVENT INTENTIONALLY MOVED THIS? - COULD IT BE THIS?
SOURCE: Dyna Glo forced air propane heater
...found out that this is a continuous ignition heater so the igniter is always on.
Posted on Sep 23, 2008
Blue Dog
  • 75 Answers
SOURCE: Hampton Bay ceiling fan - will not reverse
It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
Posted on Dec 22, 2008
Blue Dog
  • 75 Answers
SOURCE: furnace flame turning off and on off and on.
sounds like a bad thermocouple.  should be an easy fix.  Thermocouples are cheap and easily installed.  ask for details at any hardware store.
Posted on Dec 31, 2008
  • 1214 Answers
SOURCE: heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Posted on Jan 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: Fire will ignite showing flames but will not stay alight.
Turn off the gas. Remove the unit. Disconnect the thermocouple and pilot assembly. Clean the white powdery stuff out of the pilot assembly. Reconnect and try again.
If that does not do it you will have to replace the pilot/thermocouple assembly.
Posted on Mar 19, 2009
My DeLonghi PAC A110L portable air conditioner is leaking water. How do I fix this?
Hallo
If an Air Conditioner is on cooling then the Air Conditioner also removes humidity from the air any Split Unit, Window Wall A/C you name it... Any A/C on cooling dehumidify the air in the room.
To decrease the volume of the water:
1) Clean Air filter/s
2) Keep doors and windows close( can open now and again).
I don't know how that portable A/C of your look like but I believe theirs a water pan inside that needs cleaning I think it's full.( best is to service the hole A/C).
Hope this was useful.
Regards
Jun 09, 2016 | DeLonghi Heating & Cooling
I bought a DeLonghi PACC120E portable a/c with no manual. The unit does not cool, and it dumps water. How do I get it to blow cool air?
I would drain the water out of the machine via the plug on the back once the unit is drained turn on, wait a few minutes. If compressor does not come on or comes on and does not cool, you need service beyond diy.
Jun 18, 2014 | DeLonghi PAC C120 Portable Air Conditioner
My delonghi dehumidifier will not cool the house just keeps blowing warm air and dosnt feel to cool were thinking about giving up on it
Dehumidifiers aren't supposed to cool your house. If anything they generate heat. How it works is, it has cooling coils that it draws air across, which causes the moisture to condense, and be captured. However the heat extracted from the air has to go somewhere, so it just blows out the other side. If you want cool, buy an air conditioner.
Sep 09, 2012 | DeLonghi Dehumidifiers
I just bought a used DeLonghi Pinguino PAC 02. It seems to cool ok but the exhaust hose gets very warm. Is that normal?
Yes, that is normal. It's exhausting the heat from the compressor out the window.
Thanks for choosing FixYa.
Sep 09, 2011 | DeLonghi Pinguino PAC-02 Air Conditioner
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
Brand new delonghi PAC C120e, I got everything installed easily with the unit rite next to the window, I have it turned all the way down and it still does not cool my small room at night. It seems to blow...
Since the unit is new and under warranty and hopefully you have registered it with Delonghi. Your best bet, is to contact their Customer Support Rep 800-322-3848. Doing it this way has you totally covered.
Jul 12, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
I have a delonghi heater fire with pebbles - cannot see any ref no on it but it is stainless steel with 12 squares on the front below the pebbles and eight little squares each side of the bigger...
Cathy, since this is a recurring problem, it's best that you contact Delonghi Customer Care. In the USA call 800-322-3848. In Canada 888-335-6644. In Mexico 800-711-8805.
Mar 28, 2011 | DeLonghi Heating & Cooling
Delonghi pac260 ac unit blowing hot air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 21, 2010 | DeLonghi Pinguino PAC-260 Air Conditioner
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Feb 02, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Kitchen Appliances - Others Logo
79 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
