Question about Casio FX-9750GPlus Calculator
How to draw f(x,y) =x^2+y^2-2x
How to draw a 1+cos theta it a cardiod curve on calculator
  • Casio Master
  • 8,016 Answers
Press [MENU]. Highlight the [GRAPH] icon and press [EXE]. Press [F3:Type] then [F2: r=]. Enter you expression as 1+ cos(theta). If there are any functions Y=, delete them by highlighting each one and pressing [F2:Del][F1:Yes].
Press [F6:Draw]Your cardioid is drawn on the screen. This type of graph r=f(theta) is a polar graph.
Hope it helps.
Posted on Oct 03, 2009
  • k24674 Oct 03, 2009
    The equation you put in the heading is that of a circle. If you want to draw circles (which are degenerate conics) , press MENU. Use arrows to highlight the CONICS icon. use down arrow 5 times to highlight AX^2 +AY^2 +BX+CY+D=0.
  • k24674 Oct 05, 2009
    Here is what the cardioid looks like.
Complex polar angle scientific
{r, theta} is equivalent to r*exp(i*theta)=r*cos(theta) +i*sin(theta)
That is all you need.
Dec 06, 2013 | Casio Algebra FX 2.0 Calculator
X= disappeared from the Y=
You have several types of graphs
Function graphs
Y_1=f(x), Y1=3X^2-4, [X, T, Theta, n] key types X
Polar graphs r=F(theta), r=r_o*ln(theta). [X, T, Theta, n] types Theta
Parametric graphs X_1=f(T) and Y_1=g(T). [X.T, Theta, n] types T
Examples: X_1= cos(T). Y_1= 2(1--sin(T))
Sequence graphs u_n+1= f(u_n), [X,T,Theta,n] types n
Nov 21, 2013 | Texas Instruments TI-84 Plus Calculator
X= disappeared
Function graphs
Nov 21, 2013 | Texas Instruments TI-84 Plus Silver...
How do you input arccos
Press 2nd SIN 3 2 / 1 4 5 ) =
Make sure you have the desired angular mode set before you do this.
Jun 22, 2013 | Texas Instruments TI 30XIIS Scientific...
Cos theta 50
To calculate the Cosine of an angle, you first make sure that the angle unit on your calculator is set to the correct one (degree, or radian). After that it is all simple. Enter the angle value (50 degrees) then press the [COS] key. If you get an error then press the COS key followed by the angle value then press =.
Note if your calculator display Cos ( , with a left parenthesis, then you have to press COS first followed by the angle value and possibly the right parenthesis.
Note. The theta here is of no relevance.
May 27, 2013 | Casio FX350MS Scientific Calculator
Syntax error for graphs
That hardly seems possible. Try graphing the function y=x.
There are a few ways to draw curves on this calculator
  1. Drawing functions
  • Type is y=f(X), the [X,theta, T] key enters X when pressed
  • Type POLAR r=f(theta), key [X,theta, T] enters theta w. pressed.
  • Type PARAMETRIC, requires an X=f(T) and Y=g(T) functions
  • Inequality graphing. You can also draw some functional inequalities such as y> 2X^2-3
  • Dynamic graphing (graphs where some parameter may be changing)
Drawing Relations
There are some other relation you can draw X=, X>, X< , and the drawing of general conics.
I hope that the foregoing remarks help you sort out the problem you are having. If they fail to do that, I suggest that you read the manual that shipped with your Prizm.
Sep 27, 2012 | Casio Prizm FX-CG10 Color Graphing...
How to garph cos^-1 x
  1. Select the GRAPH utility.
  2. In the screen that opens, make sure the graph type is set to function Y=.
  3. If not set to function, press F3:type and select it
  4. Highlight Function Y1=, and enter the function Y1=[SHIFT][COS][X,Theta, T] and press EXE.
  5. Press F6:Draw.
  6. Change Zoom or window dimension if necessary.
Make sure that the angle unit is set to radian:
  1. Go to Main RUN screen.
  2. Press SHIFT MODE to enter SetUp.
  3. Use down Arrow to move highlight to the ANGLE line.
  4. Press F2 to set angle unit to Radian.
You will have to play with the window dimensions or the Zoom .
Jun 19, 2012 | Casio FX9750GII Graphic Calculator
The sign cos,sin and tan cannot work. Nothing appears when i press the trigo buttons. help.
When drawing function graphs of type Y1=, the name of the independent variable should be X
For polar graphs r=.., the independent variable is theta, while for parametric graphs it is T
To enter the default independent variable, press the key marked [X,Theta, T] . It will type in the correct name.
Sep 18, 2011 | Sharp EL-531VB Calculator
How do I change the mode to polar on my CFX 9850GB Plus Calculator?
  1. Turn calculator ON
  2. If you do not see icons press the [MENU] key.
  3. Use the arrow keys to move focus on the [RUN] icon.
  4. Press [EXE]
  5. In RUN screen press the [OPTN].
  6. After you press the down key once you highlight the line "Func Type"
Here is what you see.
The polar graph type is set by pressing F2:r=. In general r=f(theta). After the F2 key is pressed the Function type changes to r=
Now, if you press the MENU key and use arrows to focus on and select GRAPH, the function entry screen looks as in the picture below (without the 2cos(3theta))
After you enter the function (use the (X, theta, T) key below the [ALPHA] to enter the theta variable) press EXE to validate.
After drawing the r1=2cos(3theta) curve I opted to change the function to r1=2cos(5theta)
Press F6:Draw to draw the graph. Here is what you get.
Enjoy.
May 05, 2010 | Casio CFX 9850GB Plus Calculator
Can't transform from polar to rectangular
The e is the same, it is the exponential. According to Euler's relation
e^(i theta) = cos(theta) + i sin(theta), where i is the imaginary unit.
When represented on the complex plane (x,iy) the point (cos(theta), sin(theta)) is at the extremity of a vector of length 1 and making an angle theta with the real axis.
In (plane) polar coordinates, a point is defined by the radius r, and the angle, theta, it makes with the x axis, measured in the trigonometric (counterclockwise) direction. It is structurally equaivalent to representing it in the complex plane as r*e^(i*theta). Since r is the measure ot is radius, and the theta is it argument (angle). The complex notation is used for its convenience when adding vectors (as is AC circuits)
That is the theory.
I am inserting a clipping from the book to show you how to convert between polar and rectangular coordinates.
Oct 10, 2008 | Casio FX1.0 Plus Calculator
Casio FX-9750GPlus Calculator Logo
370 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
