Question about Acer Aspire 3680 Laptop
''acer aspire one external monitor output splits external screen picture in two'' when i plug my acer aspire one into an external screen it splits the picture on the external screen in to two, its not the monitor because a normal p.c. works through it with no problems, any help would be appreciated
    Problem Solver:
  • 16 Answers
XP - Simply on a blank part of the screen right click mouse and select properties, you should be in display properties, selections are there and you should get hte picture(s) you want
Posted on Apr 20, 2009
I am trying to connect an acer netbook to an LG tv. All I get is a no signal response. What do I do?
ensure you switch on the exteral outlet of your laptop.
for acer i am told the following
right click the desktop and choose graphics options/external monitor. ensure this is set to external monitor.
if not look for a button on your keyboard that has a monitor square shape on it. then use the fn or function key together with this key to toggle thorough, notebook screen - notebook+monitor- monitor only.
2. ensure the source is set to on TV for the input for pc monitor connection. ensure and correct monitor cable is between the input connector on your tv and the monitor output of your laptop.
hope this helps
Dec 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one ZG5....connected to another monitor pressed control key and F5. The other monitor starts to boot up windows, gets to a certain point and then shuts off connection from acer laptop, who's...
As by your description, your mainboard of the laptop is faulty as the unit fails to produce a good picture on both its own LCD and on a external LCD
May 25, 2010 | Acer Aspire 5100 Notebook
Color output to screen lacking red
You have ruled out the graphics chip by plugging an external monitor in, the chips fine.
Now you have to look at the inverter. Sometimes a cable will work itself loose from the inverter, causing the display to go wild and show strange colours where is should be white.
What you have to do is remove the screen bezel (the plastic screen surround) this reveal the screen, look at the bottom of the screen for a thin circuit board with cables coming from it and make sure the cables a plugged in properly.
If you need anymore help or advice please post back.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 3620 will not recognize external monitor.
When in windows, the 2nd monitor output needs to be turned on for it to show picture.
Right click on your wallpaper and select properties, and then settings.
You should see a page similiar to this, the number 2 would be the external display, you need to right click on it and select attach. then you can adjust its settings below and click apply.
If you don't see the 2nd display there, then it needs to be enabled in another location.
Apr 18, 2009 | Acer Aspire 3610 Notebook
Acer Aspire 5585 Laptop LCD Problem
You need to replace the inverter of your lcd screen.
Oct 02, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5003WLMi
the reason for not seeing any picture on the external is becouse it is disabled in windows. I have 3 lcd screens here, only one gives picture untill I go and extend my desktop into the other monitors.
from desktop -> right click anywhere -> properties -> settings ->
Id say the backlight is bad is your acer still covered by warranty?
Aug 10, 2008 | Acer Aspire 5003WLMi Notebook
Black Screen
If you have a picture on your desktop and nothing on your external,With external screen plugged in check the output set up on display properties,may need to be set up again.
Once the screens are identified you should be able to save these settings and remember to set the correct screen size or you may experience Black screen syndrome were your video picture should be displayed,if in doubt start at the smallest (800x600) and work from there adjusting to suit the individual requirements.
Don't for get to save before reboot then test,
Jun 19, 2008 | Acer Aspire 3000 Notebook
Acer aspire 3680
Display Toggle - <Fn> + <F5> will toggle from external monitor
Screen Blank - <Fn> + <F6> will turn the LCD off
hope that helps.
Jan 27, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
895 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
