Wi-fi on my axim x3
I need drivers for Dell True Mobile TM1200 WLAN Module
  • Anonymous Apr 19, 2009
    I NEED THE FULL SOFTWARE FOR DELL AXIM X3 TM1200 WLAN MODULE BUT U GAVE IS FOR DELL TM 1300 WLAN MODULE SO IT DOES NOT WORK
  • 611 Answers
Http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R65194&formatcnt=1&fileid=84868
try it this web stie and download it
Posted on Apr 18, 2009
Dear sir, i can not see the wireless icon on my laptop
do you have the drivers for your wifi card installed properly. if not then go to manufactures website and download driver software for your wifi unit, are you using xp or vista? find device manager and see interfering hardware.
Dec 02, 2010 | Dell Vostro 1500 Notebook
Dell axim x51 will connect to to wifi hotspot i need detailed instructions to get it to work
Hi, follow the steps found in your owners manual. That can be downloaded at this link.
http://support.dell.com/support/edocs/systems/aximx51/en/om/om_en.pdf
Using Wi-Fi (802.11b)
Wi-Fi provides your device access to WLAN (Wireless Local Area Network.)
Short for wireless fidelity, Wi-Fi refers to any type of 802.11 network,
whether 802.11b, 802.11a, or dual-band. Wi-Fi certified products from
different manufacturers are interoperable.
NOTE: Mid and High configurations of the Axim have Wi-Fi 802.11b built in and the
drivers factory installed. For a Low configuration device, you must purchase the
802.11b SD card, insert it in your device, and load the drivers.
NOTE: The default Wireless Networking Client utility for your device is the
Dell WLAN utility. The following configuration steps are for the Dell WLAN utility.
Configure wireless networking for your device in one of the following
scenarios:
• Network Card is set up
• Wireless Network is broadcasting SSID
• Wireless Network is not broadcasting SSID
If the Network Card is Set Up
Normally the internal wireless card is already set up. There are times when
you must choose the network card. On the Axim X51/X51v configurations
that have built-in wireless, the network card is associated with the enabled
wireless. If wireless is not enabled or you are using a socket card for
wireless connection, then choose the network card:
1 Tap Start → Settings → Connections.
2 Tap Network Cards.
3 Choose either Internet or Work from the menu.
4 Choose the network card to connect to the network. For the
Axim X51/X51v with built-in wireless, choose Dell Axim X51/X51v
WLAN Wireless Adapter.
5 Choose whether the network card assigns an IP address or receives an
IP address automatically.
6 Enter the Server IP addresses if required and tap OK.
If the Wireless Network is Broadcasting SSID
1 Press the wireless button to enable wireless capability. The green LED
in the right top corner of the device indicates that the wireless
is functional.
2 Tap Start → Settings → Connections.
3 To add, edit, or delete a profile, select the corresponding action and
tap Network Cards.
4 In the Configure Wireless Networks window, select one of the available
network names and tap OK.
If the Wireless Network is Not Broadcasting SSID
The Configure Wireless Networks window only shows wireless networks
that broadcast a Network Name (SSID) and those that have been added.
Add the network if it is not listed. Contact your network administrator for
the following information:
• SSID (network name)
• Authentication
• Data Encryption
• Keys (if the key is not provided automatically)
• Log in if necessary
To configure the wireless network:
1 From the Configure Wireless Networks window, tap Add New.
2 Provide the Network Name (SSID).
3 Select either Internet or Work in the Connects To box.
• Selecting Internet allows you to connect to your network but you
will have to manually start a VPN connection, if needed.
• Selecting Work automatically starts a VPN connection any time
you connect to the network.
• If you are having trouble connecting to your network, change the
Connects To box to Internet.
4 Tap the Network Key tab.
5 Enter the Authentication and Data Encryption information. If a key is
required, enter the network key.
6 Select the 802.1x tab.
7 The Authentication and Data Encryption chosen on the previous
screen determines whether this screen is available. If available choose
the EAP type used on the network.
8 Tap OK.
9 If more than one network is listed, tap and hold the stylus on the
network name you want to connect to. A pop-up menu appears.
Tap Connect. After a few seconds you should see Connected next to
the wireless network you selected.
Thank you,
lee
Mar 09, 2010 | Computers & Internet
Windows Vista will not recognize dell axim X3
I have had that problem with other USB devices i suggest trying a different USB port as the USB port you have used to connect the X3 to is most likely malfunctioning.
Aug 10, 2009 | Dell Axim X3 Pocket PC
Hello Experts, I have a second hand dell axim x3. I am trying to use internet. The X3 says I have a WiFi connection. But when I go to the internet of e mail, the x3 says that the page I am looking for can...
Have you set up the Connection properly on the X3?
As i have had a similar problem with the X30 i had to go through the network connections config and fiddle around with them until it connected properly. sorry i could not provide any specifics in this situation as it has been at least a month since i set it up.
Jul 10, 2009 | Dell Axim X3 Pocket PC
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
Software
If you are using Windows XP, you can download Acivesync 4.5 from Microsoft's website, and by this software you can connect your PDA to your laptop (You'll need Windows Mobile Device Center if you're using Windows Vista).
Note: Most probably you won't need the PDA's CD, when XP detects the USB device, if it asks for, point it to C:\Program Files\Microsoft ActiveSync\Drivers and it should install perfectly. But normally Both XP and Vista can recognize Dell Axim PDAs.
Apr 15, 2009 | Dell Axim X3 Pocket PC
Looking for a Wi-Fi card for a Dell Axim X5 Pocket PC
According to http://www.socketmobile.com/pdf/wireless-lan/go-wi-fi_spec.pdf it looks like you have to have Windows Moblie 5 or 6 or Windows CE.
The Axim X5 can only go up to Windows Mobile 2003 (Mobile 5 is the one after this).
My suggestion is sell the REALLY great Socket card and get one that works with your X5 (you have either Pocket PC 2002 or Windows Mobile 2003) If you Ebay search Dell TrueMobile, you'll find the card that works with either.
I need mine too, so it looks like we'll have a bidding war.
Apr 23, 2008 | Dell Axim X5 Pocket PC
Installing San Disk Wireless Lan Card for Dell AXIM 5
Actually the reason why it's saying that is because that card is not compatible with the Dell Axim X5 because if it was you wouldn't get that response. I'm still looking for a Wi-Fi card for mine as well because I ordered the P500 Wi-Fi compact flash card from Dell then come to find out it wasn't compatible with the Axim X5, it was discontinued.
Jan 22, 2008 | Dell Axim X5 Pocket PC
I can't connect to the internet with my dell axim x30
I have the same problem. I have a router and WLAN in my house. I actually connect to the network, the pocket PC says the strenght of the connection is Excellent, even green connection bars, in the right-bottom corner are visible.. But when I try to ping any other computer connected to the network it says NO RESPONSE, not mentioning being unable to surf the net with browser. However, i recall that if you have some wierd kind of encryption, ie. WEP, or WPA or some other - some devices can have problems connectiong to the router(access point). Please somebody comment on what i've mentioned.
Dec 09, 2007 | Dell Axim X30 Pocket PC
Dell Axim doesn’t support serial connections?
There is another thread on this board where a number of people talked about serial connections and alternatives. I also want to connect my existing AirMap 100 GPS via serial cable. The Dell moderator (Rollie) pretty much put an end to that thread by stating: "A serial cable is not available @ this time and when one will be available is unknown"
Sep 13, 2005 | Dell Axim X5 Pocket PC
Computers & Internet Logo
202 people viewed this question
David Payne
David Payne
