Question about Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW - checking toner level
I have the above mentioned printer. Is there a possiblility to check the level of remaining toner?
Thank you.
  • Anonymous Mar 14, 2014
    where to get a new waste toner box
  • Anonymous Mar 16, 2014
    HOW I CAN RESTART MACHINE COPIER BROTHER MFC-9840CDW
On my APPLE the MAC OS driver depicts the toner levels when I check the printer status under the settings and preferences - printers icon - supply levels is an optional choice. I have not found a way to check the levels on an XP system.
Posted on May 07, 2009
How do I get a toner coverage report from a Sharp 2610C?
How do I monitor toner levels in my Sharp copier or MFP? You can monitor the toner levels in your Sharp copier or MFP by pressing and holding down the COPY function key . Two pieces of information will then be displayed.
The Total Copy count on the device
and
The remaining toner levels. This will be shown in 25% increments. When you get down to 25% capacity check to see if you have spare toner on hand. If not, give us a call and we will promptly deliver.
How do monitor toner levels in my Sharp copier or MFP
check out the user manual too:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0ahUKEwja6dWd9fLMAhXGlx4KHegRC24QFghIMAc&url=http%3A%2F%2Fwww.wisconsinimaging.com%2Fdownloads%2Fmx3610nManual.pdf&usg=AFQjCNEyIj_mysubFXRIlvDoqEKBw3L4zQ&sig2=0jtdA8-CGBc2ej3tWvEdHg
it stated
To view the approximate amount of toner remaining, continually touch the [Home Screen] key ....
May 24, 2016 | Sharp Office Equipment & Supplies
CHECKING THE INK LEVEL
to check the toner level just press the button and wait the second light(orange) to turn On and then release the button. The printer will print two pages one with configuration and one with the supply status of the toner cartridge
Dec 26, 2015 | HP LaserJet 1300 Printer
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
Print is blurry
Remove the toner cartridge and print cartridge assembly. Slightly shake it from side to side to redistribute toner properly. Also, please check the supply level of your toner cartridge.
You might want to consider replacing the toner cartridge since you have already replace the PC unit.
Also, check the transfer roll for signs of toner buildup and contamination.
Inspect the HVPS contact (transfer roll) for contamination. Verify the high voltage cable is plugged into the LVPS/HVPS.
If all the steps mentioned above were done. I would suggest you contact Lexmark Technical Support for further assistance.
Apr 04, 2012 | Lexmark E360d Laser Printer
How can tell if the ink level is low? hp 2420
Cartridge comes along with memory, the information of estimated ink/toner levels will stored in this memory(Depends upon the cartridge model yield will varies). When printer performs the printing, memory count will comes down, when its reaches the minimum count printer will display the message of "low ink/toner/remain pages" levels, once its reaches to '0', display will changes like "replace the cartridge"...But there is no electronic component or mechanism to measure the ink/toner levels in the cartridges.Only estimated levels only printer can recognizes.. Take usage page through menu, you will get the information that usage % & printed pages info,you can judge how much remain it can print...
Dec 06, 2011 | HP LaserJet 2420 Printer
Is there a way to check how much toner is left?
Hello thanks for using FixYa
If you want to check the toner level in your Canon laser printer on a regular basis to make sure you have an extra toner in-hand when needed
To check it follow the given instructions:
  • Click on the Start button and select "Control Panel"
  • Double click on Printers and Other Hardware."Click on Printers and Faxes" If you use Windows Vista or above, click on the Start menu and select "Settings"Click on "Printers"
  • Click on the icon of your Canon printer. Open the "File" menu and select "Printing Preferences" This will open the "Printer Properties" dialog box.
  • Click on the "Maintenance" tab and hit the "View Printer Status" button. This will show you the toner levels in your Canon laser printer. The "!" symbol appears when the tank is low. You can continue printing, but not for too long. This is a perfect indication for you to purchase a new toner. The "X" refers to an empty tank which requires immediate replacement.
I hope this solution will also helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 23, 2011 | Canon imageCLASS MF5750 All-In-One Laser...
The orange light is blinking. Above the light is a triange with an exclamation point in it. I have tried deleting and reloading the printer and that doesnt work.
Do you have a new toner cartridge loaded? The red/orange light will blink when toner is low, even if everything else is working fine. Try printing out a test sheet and see what that tells you about your toner level. (Test sheep prints by holding the orange button down a second or two and releasing.)
Since I'm mainly printing drafts for my own use, I've just let the light blink while I eke out whatever I can from the remaining toner (occassionally removing the cartridge and shaking it -- being careful of clothes and surroundings -- to re-distribute the toner on the inside.
Oct 17, 2010 | Samsung ML-2510 Laser Printer
Problem with Dell 1720 printer
Hello
You have to check couple things in this case.
Ensure that the printer cover is closed.
  1. Remove the toner cartridge.
  2. Firmly shake it side-to-side and front-to-back several times to redistribute the toner.
  3. Reinsert the toner cartridge, and continue printing.
Repeat this procedure multiple times until the print remains faded. When the print remains faded, replace the toner cartridge.
or
The imaging drum is approaching full and needs to be replaced. Order a new imaging drum.
Apr 30, 2010 | Dell 1720dn Laser Printer
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
Brother MFC-9840CDW Laser Printer Logo
4,519 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
