Question about Compaq Presario Notebook
Black screen well my laptop has a black screen, its seems to be running but even the external moniter is getting nothing
  • 489 Answers
If you dont have any view on external monitor too  there so 2 reasons for.  1 is mainboard (graphic chip) 2 is LCD data cable that comes from Mainboard and goes to LCD.  need to go to Service
Posted on May 29, 2009
HP laptop wont start up or wont connect to moniter
If you plug the VGA external lead in before powering the laptop up. If nothing on the screen and because the fan is running hard, there may be a GPU issue caused by over heating. The GPU may need the solder removing and leaded solder replaced to get it to work again. A specialist job!
Dec 11, 2013 | Computers & Internet
When my computer is on the moniter is blank.
The monitor only has one cable and it is keyed to fit one way. They are always located under the top bezel. Should have roughly 20 pins and the wire will flow up into the display. If the screen is very very dim (look carefully) then your inverter board is most likely bad these run 40-120 dollars depending on model and are located along the bottom edge of the display itself. If the screen is completely black, try plugging an external monitor into your laptop (make sure you try toggling the display mode) [typically Fn + F7 or whichever says LCD or has a monitor icon.] If the external monitor works then your screen is most likely the problem and will need to be replaced. If the monitor does not work, the motherboard needs to be replaced. You will be hard pressed to find any schematics for motherboards but you could dis assembly the the laptop and easily check for descended capacitors, burns and the light though most of the time I doubt you will be able to see the damage.
Best of Luck
Jan 24, 2012 | Computers & Internet
Problem for Acer Aspire 5315 PC Notebook. This notebook will power up but nothing is happening on the moniter and even on a external moniter. I cannot tell if it is even booting as the hard drive light or...
have it check with the service center, the problem is no in your hard drive, or ram. or even your monitor, it has something to do with your video card, and you'll need to take out all to cover to get access to it, so I suggest better bring it to a service center to avoid more damaged
Nov 05, 2009 | Acer Aspire 5315 Notebook
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Blue screen on notebook monitor when hooking up external monitor
hold dowm the Fn key and keep tapping on the F5 key..
Jul 05, 2008 | Acer Aspire 3680 Laptop
Fujitsu siemens 8830
check to see if lid switch is functioning correctly if possible.
if **thing seen,** change ,inverter board needs replacing.
you've tried changing moniter so it isnt cable connections internal or external.
you're **t hearing any beeps so it isnt video,mem or hd.
Mar 01, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Compaq Presario Notebook Logo
110 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
