NetGear DG834G Router
Problem for NetGear DG834G Router
Network routing problem with Axis Camera's
By aaxford on Apr 17, 2009
Hi, can anyone help me. I have a restaurant where we have just upgrade the web cameras from static images to live video feed. We had 1 camera doing live feed already and were able to set up port forwarding for this static ip address to allow us to access over the web. We just installed 3 new cameras and again set up port forwarding. The cameras work perfectly on the LAN but we cannot connect to them via the internet. I can access the router and the 1 camera over the web but not the others. Can anyone suggest what might be causing this problem. thanks
Clarification Request
Posted by solderfix on May 10, 2009
I believe the problem is that you have only one IP address and you really want to share more than one IP address (because of the 3 additional cameras)?  There is something called "dynamic DNS" that can allow this, but your router and/or cameras would need to support it.  In looking at the information on your router it doesn't appear to offer support.  What model(s) of Axis camera's do you have?
Solution #1
posted on Nov 22, 2009
Not Rated)
3764alan
Rank: Wiz
Rating: 82%, 52 votes
They would need to be on different TCP or UDP port numbers ... in order to access them from the Internet. I'm guestimating that on the LAN you can access all of them because they are on different RFC1918 IP Addresses (e.g. 192.168.1.10, 20, 30) but same port number (e.g. port 80 for web.)
Once you hop through NAT to get to the Internet you now only have one IP Address. The real Internet IP Address. So now you have to have different port numbers for 2 or more cameras. For example use:
#1 port 80
#2 port 8080
#3 port 8081
#4 port 8082
How about that?
And you will have to forward each of those ports to the correct ip address for the correct camera.
Where's my free restaurant dinner? :-)
Was this helpful?
Yes
No
Popular Solutions for NetGear DG834G Router
Questions and Unsolved Problems for NetGear DG834G Router
Do you recommend NetGear DG834G Router?
Answer
Answer
How can i restrict Xbox chat on Dg834g
Answer
I have two routers Netgear DG834Gv3 and Thomson SpeedTouch TG585v7. I want to create a wireless... (More)
Answer
note system worked perfect for the last 3 months,thank you for your time fred
Answer
non ho capito cosa devo fare con il mio router negear dg834gv3
Answer
we have 2 new itouch devices in our home . 1 is connected to the wi-fi qnd the other will not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For NetGear DG834G Router:
Top Router Experts
Rank: Guru Guru
Solutions: 1349
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
