Question about Microsoft Windows? Vista Home Premium Edition Upgrade Version for PC (1 Computers) (66I-00021)
Hi, I am facing a problem with my external hard drive, TEAC HD35puk, and as soon as I connect the usb then I can see the window saying that the new hardware is installed I also can see it in the device manager and there are no conflicts but when I open 'My Computer' I can see it, Can you help?
  • Mikael Guggenheim
    Mikael Guggenheim May 11, 2010
    Is it new? Have you checked that it's assigned a driveletter in Drivemanagement?
    Do you know what system it is? (Fat, fat32, dynamic, etc.)
    Sergeant:
  • 239 Answers
For this usb file support hard ware have to install properly or clear the lens for virus after then the problem wil not revole. using the usb properly disconnt
Posted on Apr 17, 2009
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Just bought a teac fd-05pub usb portable diskette drive. i have a dell computer with windows vista. when i pluged it in the device was installed, however the power light comes on for a few seconds then...
The below is on the basis that the drive is visible in "Computer"...
This can be tow thing, one the drive is not receiving enough power from your USB port, try unplugging any addtional USB devices connected to the PC, if this doesn't work try a powered USB hub. Second the floppy disk is faulty or the drive itself is faulty.
Hope this helps, let me know how it goes.
Thanks
Jul 11, 2011 | Teac FD-05PUB External Floppy Drive
I have an external harddrive from TEAC and for some reason sometimes i can connect it to my laptop but lately most of the time windows gives me the message that the "USB Device not recognized"
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 01, 2011 | Teac HD10U5/KIT 5 GB IDE Hard Drive
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
We have a TEAC FD-05PUB external floppy drive that we are unable to run - system is Windows xp - we can connect to other PCs and it works fine. Thought perhaps it was the drivers but unable to located any...
The USB Floppy Drive shouldn't require drivers under Windows XP (according to TEAC, here: http://goo.gl/BvTcV).
Make sure your Windows XP installation is completely up to date, as Windows Updates often contain driver updates as well as system updates. If this still doesn't work (or your system is already completely updated), there are some additional troubleshooting options here: http://support.microsoft.com/kb/283658.
May 03, 2011 | Teac FD-05PUB External Floppy Drive
Vox External Hard Drive - Unknown Device???
My drive will do that if the external power to the drice isn't working.
Mar 14, 2010 | RPM Vox 750GB 3.5in USB 2.0 & eSATA...
I am trying Windows 7 and need drivers for my TEAC USB hard drive
did you check the company page of the hdd developer recently? the new drivers are getting on the web on a daily basis, aspecially since the vista has a completely new sistem that makes the hardware developers pull their hair out (what have they done to the perfect xp system??)
Feb 21, 2009 | Teac FD-05PUB External Floppy Drive
External hard disk installation
plz check your usb port if other device read ...........then your external hard disk so error. or if ex hard ok...you install windows vista .
Jan 19, 2008 | Computers & Internet
My External Hard Drive
Try and find drivers for it on manufactures website. the description does not say windows vista compatable. good luck on finding solution
May 29, 2007 | Teac HD2U80 (HD2U80KIT) 80 GB Hard Drive
Microsoft Windows? Vista Home Premium Edition Upgrade Version for PC (1 Computers) (66I-00021) Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
