I cant get my computer to acknowledge the new hardware when when i connect the expresscam, the software i recieved with the camara was corrupt i need to install the correct drivers and the get the instilation/set up software
  • 28 Answers
Get a download of the software for free from the internet
Posted on Apr 26, 2009
I have a 'new' aspire one netbook and i cant make work. it says in need to be connected to a network. ihave an acerlaptop that works just fine on network 7AP13. i am connected verizon fios and am not
That means there is a corrupt or a missing wireless driver on your new acer laptop. First of all if you are using Windows XP follow the following
1. Go to start
2. Right-click on "My computer"
3. Go to "Properties
4. Go to Hardware tab
5. Go to Device manager
In the device manager check for any yellow question mark or an exclamation mark. Especially on the network adapters. That means if you had the network drivers working before, then they are corrupt or they are not there at all.
Here is the solution..
visit acer.com and go to their downloads and support tab, you will be abel to see the model of your computer and you can download the wireless drivers that are compatible with your laptop.
Nov 15, 2011 | Acer Aspire One PC Notebook
I just moved apartments, reset up my printer/computer, now computer is not acknowledging the printer. When I try to print it will say "connecting, 78% completed) and then nothing actually comes out.
MAKE SURE YOU HAVE YOUR PRINTER SET ON DEFAULT AND THAT IT IS INSTALLED PROPERLY! OR YOU CAN ALSO TRY...UNHOOKING YOUR PRINTER, SHUT DOWN YOUR COMPUTER AND HOOK YOUR PRINTER BACK UP BEFORE RESTARTING TO LET YOUR COMPUTER INSTALL YOUR PRINTER.
IF YOUR COMPUTER DOESN'T RECOGINIZE NEW HARDWARE, SUCH AS YOUR PRINTER, THAN IT IS NOT SET AS YOUR DEFAULT PRINTER!
YOUR SOFTWARE MAY NEED TO BE CORRECTLY INSTALLED, MAKE SURE YOUR PRINTER IS NOT HOOKED UP WHEN INSTALLING SOFTWARE.
SOFTWARE HAS BE INSTALLED FIRST, AND RECOGNIZED...THEN RESTART COMPUTER WITH PRINTER (HARDWARE) HOOKED UP!
Aug 25, 2011 | Office Equipment & Supplies
Windows xp says no drivers for this device
hi try this ... if you are installing a new device it is recommended that you install the software first then restart your pc and plug/connect your device !then go to Start,control panel , add hardware follow the on screen instructions add new hardware /yes i have connected the new hardware( then if you cant find the new hardware) just choose/ add new hardware device /search and install automatically !it should find the files for it to install properly
please rate this if found useful , many thanks it only takes 1 second
Dec 21, 2010 | Computers & Internet
Can I download pictures from my digital camera onto my Dell Latitude d410? If so, how?
You can download from any digital camara.Load the CD that came with the camara or obtain one if you can. You need the interface cable that is purchased seperately. You do not specify the camara spec so you will need to Google the" model and pc interface cable". If you have the cable then the next step is the camara driver which should be on your cd that came with the camara. Plug in the cable to the camara and to the USB port on the PC (make certain the camara is set to the Play position or PC). Windows will ask for the driver location. Insert the cd and continue. If windows does not see the driver you will need to locate it manualy from the cd or on line and download it to your desktop from the manufacturers web site. All camara companies have a support website for the drivers. Once the drivers are loaded then you need to switch the camara to the Play position so it can be seen by the computer. Go to the control panel in windows and select system then hardware then devices. If all went well you should see the camara listed as a device. Now you need the camara software or a picture viewer from the web. Here is the web kocation http://en.kioskea.net/telecharger/telecharger-653-picture-viewer
If all went properly 1. driver 2. picture software then you should be all set to handle your pictures. Good Luck Phil pmgibs1@verizon.net
Feb 20, 2010 | Dell Latitude D410 Notebook
Digital camara and memory card
Basically picture files in memory card have corrupt data that's why computer doesn't recognize it.
HP recommends following action...
Close the HP Image Zone or HP Photosmart Software, disconnect the camera from the computer, and reset the camera. (can see this at HP Support)
2nd option is to find some memory card data recovery software on internet and use it to correct data files in memory card.
Thank you.
Oct 03, 2008 | HP Cameras
Bluetooth 2.0 EDR Undetected by Computer
Hold the red button in while inserting the dongle will give you bluetooth.
Mar 10, 2008 | Logitech Cordless Desktop MX 5000 Laser
Sony Handycam DCR-SR42
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall, reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfixIf that doesn't fix it try the USB cable
Jan 30, 2008 | Sony Handycam DCR-SR42 Camcorder
Belkin USB/adaptor
Google Franson GPS GATE this little software utility is what you need
Mar 31, 2007 | Belkin USB/Serial Portable Adapter...
No signal from the link light
Rich, go into control panel|system|hardware|device manager and select your card. Right mouse click | update driver. Try to have windows do it..if not point the installer to the setup disk. Tim
Aug 02, 2006 | Zyxel ZyAIR G-302 (760559111205) 802.11g/b...
Computers & Internet Logo
David Payne
David Payne
