Question about Dell Dimension 4100 (-JM0TB01) PC Desktop
Graphics driver not found
Sir,
i m used dell dimension cpu 4100.
i want to play cricket game on
but in grahpics card driver are not installing plz help me
see on net garphics card driver for down load
  • Jim Scott May 11, 2010
    what brand of graphics card are you using ??
  • 298 Answers
Please go here and enter your information where asked;
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
after you download the driver you still have to install it.
Double click on the file and run it untill it says finished, you may have to reboot.
Posted on Apr 17, 2009
Help with upgrading Dell Dimension 4600 GPU
June,
The Dell Dimension 4100 Desktop PC, utilizes an AGP slot on the motherboard, for a graphics card.
http://en.community.dell.com/support-forums/desktop/f/3514/p/17152514/17275500.aspx
There are different styles of AGP expansion slots.
The one on your motherboard was the last current style of AGP -
AGP 8X
Therefore your Dimension 4100 uses an AGP 8X graphics card.
It is (Was) an Nvidia GeForce FX5200 graphics card, and the AGP 8X style.
http://en.wikipedia.org/wiki/AGP
To replace it just use a graphics card that is AGP 8X, and is better, or equivalent to the GeForce FX5200.
You also need to know that your Power Supply in your computer, will handle the power requirements for the computer system, AND your new found AGP 8X graphics card.
Power Supply was rated, at a maximum Wattage rating of 200 Watts.
Problem is; that back in the day when the Dimension 4100 was made, the Power Supply manufacturer 'Fudged' the real Wattage specifications.
Power was (Is) more like 60 to 70 percent of what is stated.
Divide 200 Watts by 10
= 20
Now take that times 6, for 60 percent.
= 120 Watts
Now take that times 70, for 70 percent.
= 140 Watts
ACTUAL power
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4410189&CatId=2234
I would recommend this one, but it requires 250 Watts MINIMUM,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=853908&CatId=2234
[Graphics card manufacturers, base the Minimum power requirements for their graphics cards; based on a test computer system.
So the Minimum power requirement stated, is not only for the graphics card; but ALSO the rest of the computer.
The test computer system is usually based, on all of the top of the line, power consuming hardware components; of that time
Top of the line powerful Processors, and Motherboards.
Add to that the maximum amount of Ram Memory, that can be used.
Two optical drives, (CD/DVD drive)
Processor fan, and at least two computer case fans ]
KNOW THIS:
A) FOLLOW Anti-Static Procedures
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer, and BEFORE taking any new parts out of their Anti-Static bags, or cartons.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return
B) Windows running on your computer, PUT the Installation disk that comes with the graphics card, in your optical drive tray.
(CD/DVD drive)
Install ALL software.
There will be Drivers you are installing, and also a graphical user interface. (GUI)
The GUI for an Nvidia graphics card, (Evga GeForce 6200 is an Nvidia card), is the Nvidia Control Panel.
(For ATI it's Catalyst Control Center)
Driver: Small piece of software that allows the Operating System to communicate with a device
In this case the device is the graphics card.
What version of Windows operating system was not stated.
-> AFTER <- you have installed the software, and if it asks you do you wish to restart your computer; the answer is -> NO
Close all windows, go back to your desktop screen.
Now turn the computer off normally.
Follow Anti-Static Procedures, and Physically install the graphics card.
Note*
The AGP expansion slot on the motherboard, will have a type of Locking Arm on it. With most the end of the arm, has a 'fingerdip' in it.
Makes it look as though you press DOWN, on the end of the Locking Arm, in order to release it. (Unlock)
Actually you GENTLY pull up a little on the PLASTIC Locking Arm, to release it.
Release to remove the old graphics card, and to install the new one.
After the new graphics card is installed, attach the monitor cable to it, and close the computer case.
Turn the computer on.
You MAY have to go into the Nvidia Control Panel, and set Screen resolution, and other parameters.
(Look up your monitor by it's manufacturer name, and model number. {Back of monitor - Model Number}
See what the Screen resolution is.
Example - 1280 x 800 pixels
Set Color quality to High (32 bit)
Have additional questions please post in a Comment, or Reply.
(Below my solution)
[When a device is installed on a computer with Windows, Windows will 'break it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This = NO
A Driver Conflict can result.
Windows: "Which drivers do I use? These or THESE?"
With THE drivers installed first, Windows will find them.
May 06, 2013 | Dell Dimension 4600 PC Desktop
Graphices no tworking
Most of those games are dependable of RAM's and Windows XP are outdated since ten years ago, Call of Duty is not duable in less then Windows Vista enviroment.
graphic cards name and model?
have all the DirectX files updated?
have at least 4 gigs of RAM?
Mar 23, 2012 | ASUS P5G41CM LX Motherboard
Graphics driver not installed properly
reformat your computer and reseat the card. if those fail the card is dead
Mar 09, 2012 | Video Game Consoles & Games
I have a 768 ram pentium r 4 cpu 320ghz ,when streaming picture quality and buffering is poor can u help pls
make sure your Grahpic card has enough memory, see install the latest driver for your video card.
Oct 23, 2011 | Computers & Internet
I have purchased a asus p5g41c-mlx motherboard on jauary 2011 .but after 2 month its grahpics not work properly ,it is flickering ,i have using window xp. i have uninstal the grahpics and reinstal it but...
Hello there,
Here is *********** boards VGA details.
Integrated Intel GMA X4500 graphics Maximum shared memory of 1GB
Supports RGB with max. resolution 2048 x 1536 (@75Hz)
Supports Microsoft® DirectX® 10
Here are the system requirements of the games you are currently playing with problem.
NFS Most Wanted- It should run with no problems just avoid high detail settings.
Minimum: 32MB or more, ATI 7500 or greater; ATI Radeon Xpress 200; NVIDIA GeForce2 MX/GTS or greater Recomended: NVidia 5900 or ATi 9800 with 256mb of video memory
Prince of Persia Two Thrones
Minimum: 64MB Recomended: better than recommended in NFS Most Wanted
COD Black Ops
Minimum: Shader 3.0, 256MB GeForce 8600GT/ ATI X1950 Pro or better. Recommended Nvidia: GT 240 or higher Recommends Ati: HD 4670 512MB or higher Minimum Memory: 2GB
Some games have hardware validation test if your unit fails to the requirements you cannot install the game. try to download this BurnIn. Select the 32bit Standard edition. install the utility and stress your x4500 graphics. Sir you did not post your Processor and Memory. The x4500 graphics will use 128MB of your ram, If you are using 1GB or 1024MB - 128MB = 896MB. 2GB or 2048MB - 128MB = 1920MB. For Memory system requirements your system failed and the main problem is your video card.
Hopefully this helps.
Thank you for using FixYa.
Jul 22, 2011 | ASUS Computers & Internet
Hi ..I am trying to play EA Sports Cricket 2002 in my Laptop with OS Windows 7. The game application is loading & opening properly but while I am pressing any key to play, It crash down & exit to...
sir that is because of your graphics card.sometimes your graphics card is an ordinary one or sometimes your graphics card is not stoppered with that game.please try geforce 9400 gt.It is the best graphics card it will support all kind of game
Mar 26, 2011 | EA - Electronic Arts Cricket 2002 for...
Font problem in ea sports cricket game
its not the peoblem with ur cricket game its a problem with your graphic card if u are using xp and have installed the drivers for vista this problem may come so try reinstallingthe graphic driver fron the motherboard cd
Jul 03, 2009 | EA Sports Cricket 07 for Windows
Can a Dell Dimension 2400 take a GeForce 6600 graphics card?
This card can only Be installed in a Tower CPU. Your Card slot will not Accept this.
Jan 23, 2009 | Computers & Internet
Problems with Dell Dimension 4100 PC Desktop
maybe your dell dimension needs an audio driver. you can find drivers here by inputing the model or the service tag number. service tag found at the back of your PC.
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs&~ck=mn&SvcTag=&SysID=DJ_DIGITAL_MP
Just follow instruction if your were in the site.
if this not solve;
try another audio card.
Jan 02, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Dell Dimension 4100 (-JM0TB01) PC Desktop Logo
56 people viewed this question
Alun Cox
