Dismantle a fujitsu amilo 6825
I need to know how to dismantle a fujitsu amilo 6825. i cant get the silver bit off above the keyboard.
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
I need a new fujitsu siemens amilo ms2212 keyboard. anybody knows where can I to buy one these?
I would check on eBay and do a web search with as many params as possible, such as:
Adding the keyboard part number to above would narrow the results even better
Apr 05, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
How do i turn my wirless connection on my fijitsu siemens amilo pro
Gateway Laptop ---- Switch on side and then Fn / F2
Apr 02, 2010 | AT&T Siemens S46 GSM Cellular Phone
Wireless connection
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Fujitsu AMILO PC Laptops
Hardware switch on a amilo fujitsu laptop
On some of the Amilo Models, the Wi-Fi button is actually a key combination on the keyboard. Have a look for a key with the wireless symbol on it - looks a bit like an antenna, and hold Fn while you press that key. Your Wireless should come back on.
Fujitsu's can be odd, cause the hardware button (mentioned above) doesn't actually disable the driver in Windows, just turns it off so no connections appear.
Mar 05, 2009 | Computers & Internet
Fujitsu amilo pro laptop , keys don't work
am afred u have dropped liquid on the keyboard please try to clean it if still dosent work please take it to a qualified lapto technician
cheers
Jan 24, 2009 | Fujitsu AMILO Pro V1000 Notebook
Memory uprgrade
You have to remove the keyboard, under the keyboard to the left is a heat shield (silver metal cover), remove it. Your ram is located there. Just take your time and remember where the screws go.
Jan 22, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Replace keyboard for fujitsu siemens amilo pro v3515
Hello Den,
1st remove the Battery ..u will find screw below the battery ..unscrew it and then remove the blastic bar above the keyboard which contain the power ,wireless..etc Keys ..afterthat u can remove the key board and replace the new one...
Best luck
Nov 30, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu Amilo L7310
I have L7310GW - maybe it is similar.
The BIOS battery is deep inside the case and needs full strip down to reach it. I know because I have just taken one apart. Need to undo all screws on base and remove keyboard and screws under that and hinge cover screws and steel plate under keyboard and remove mother board to find it.
Good luck
Jul 09, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Computers & Internet Logo
265 people viewed this question
David Payne
David Payne
