Question about Motorola Mobility RAZR V3
Doesnt let me click
It doesnt let me click button i have to press it for a long time.
Its easy just clean ur keypad.. thn check it again..nd also keep pressing it for 30sends and after it vibrate is slowly it will cums bck to its previous place... :)
Posted on Sep 18, 2007
Treadmill wont speed up
RUN the software calibration for diagnose, and fix it.
God bless you
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jan 06, 2013 | Exercise & Fitness
I need a code to program a remote for a sanyo tv
all you need to do is press the code search button until the red light is on then press tv button...then point the remote at the tv and continue to press the power button until your tv turns on/off...then press enter. Be patient...it may take any wear from 2 or three clicks up to 100 clicks....but it will eventually operate your television....be careful though...if you press the power button even 1 more time after it turns your tv on or off...you will have to start all over....Good luck! and if this doesnt work..you can always buy a universal remote from any department store..some are as cheep as 5.00. and they all come with program guides.
Nov 03, 2011 | Sanyo DP42849 42 in. HDTV
The left mouse button doesnt work every 4th press...
I believe the switch inside the left mouse button has worn out or broken that made you think after pressing 4 times you were able to trigger the switch and make the mouse to work. You may open your mouse carefully to see if this is the case. If not please follow the below steps as you might need to configure the mouse double click speed.
Open control panel>Double click on the mouse icon>Button Tab>Double Click section>Adjust your double click speed.
Jul 19, 2011 | Computers & Internet
How do you program my remote on my prostart as the battery died and i replaced and still doesnt work?
press the hood pin switch down for 4 sec, release then press and release again, turn your key on and then off and hold the lock button down on the prostart rmote until the unit clicks 5 time then release
Feb 27, 2010 | Samsung Phone PDCSLCD12B
My Iphone 3g doesnt turn on.. I only get the apple when powering up and then a black screen.. I tried charging it all night (different chargers) and doesnt work.. I tried rebooting many times.. that doesnt...
If you just see an apple logo or your phone does not turn on, there is a software problem and you will need to restore your iPhone. I didn't want to hear it, because now I had to redo everything; but it's the only solution.
Put your iPhone into recovery mode.
To put your iPhone in recovery mode:
Step 1: Plug in your iPhone to your computer, make sure your sound is turned on and not muted.
Step 2: Hold the top corner button for two seconds. You should hear a sound.
Step 3: Now, still holding the top power button, immediately press the home button and hold both buttons for 10 seconds. You should hear another sound from your computer.
Step 4: Release the power button but *continue holding the home button*, for another 30 seconds.
Step 5: Meanwhile, continue holding the Home button and open iTunes. Wait for it to tell you that it’s in restore mode. You should also hear a third sound from your computer during this time.
Step 6: Click on your iPhone in iTunes. It should say it's in recovery mode and need to be restored. Step 7: Click OK and restore it.
Now you will need to re-jailbreak it, and restore your backup, and also put your music back in.
Good Luck!
3ONO
Email : xxxxx_2079@yahoo.com
Dec 08, 2009 | Apple iPhone Smartphone
Our ym doesnt show any frends on my list, its totally blank, what should i do?but when i used action button, thats the only time i can see my friends through separate windows
Click on Contacts .... click on Show/Hide select Offline Contacts or press Ctrl+H.....Now you will able to see full contact list.....Have a good time....
Oct 27, 2009 | Yahoo Messenger
Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Mar 10, 2009 | Bose Cinemate Digital Home Theater System...
I think i have disabled the remote how do i enable it
you have to hit the star or start button twice...if that doesnt work try hitting the trunk button three times...each press should be a second long and a second inbetween presses...hope that works
Jan 16, 2009 | 450-R Deluxe Remote Starter with Keyless...
The red light keeps on flashing
HI-
Turrn off the printer then unplug it for a few minutes. replug it then try pressing the maintenance button once or press and release it, if it doesnt move to position where you can change it press on it again. If this doesn't help. Go to start on your computer, go to setting then control panel, click on printers and faxes( then right click on the printer icon and left click on printing preferences then) look for utility or maintnance tab then there should be an option to replace ink cartridge.
Keep me posted
Sep 15, 2008 | Epson Stylus C43SX InkJet Printer
Cant on my coby MPC-7085
first just charge it before you go to sleep and dwhen you wake up the next day check....dont ever reset it because all the settings reset also which means the light on the keypad may not work to make light on the keypad...turn it on...scroll down to setup..click it and scrol down to display,,,click that then click backlight and put how many seconds you want it to stay on...mine is 11 sec.(the thing is from 3sec-11sec.)
May 25, 2008 | Coby MP-C7085 MP3 Player
Motorola Mobility RAZR V3 Logo
21 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
