Question about HP Pavilion tx1000z Notebook
Pavilion TX1000 - WiFi card suddenly not detected
I have a Pavilion TX1000 running factory-installed Vista Home Premium After one year suddenly it does not recognize that it has any WiFi capability.I try to re-installation hardware( Brodcome wireless Lan -vista) .After complete re-installation , says press ok to restartyoue computer . I click ok to restart my laptop but unfortunately it can start agian. Do you know why? Any ideas?
The solution is, get a USB wifi adapter, because that card is done. HP REFUSES to recognize this problem, and since the majority of failures happen after the warranty expires (mine did) HP just says you are SOL. You can get decent wireless adapters for $20, and your wireless problems will be solved. Unfortunately, expect your laptops motherboard/chipset/dc port to fail within a year :(
Posted on Apr 20, 2009
Recently I upgrade my 400sd4 to 512 memory, anew hard drive 160gb and loaded in vista home premium. Now my wireless adapetr linksys wireless-b causes the computer to freeze and not load. I tried loading...
I suspect your problem is with the drivers for that WiFi-B card. You didn't say what the make & model is of that card, but most manufacturers have not updated their older products for Vista (older WiFi-B & not-so-old WiFi-G cards included). If you're trying to force some older Windows 2000 or XP drivers to work in Vista, you're bound to have issues. You may need to replace that card with a new WiFi device that has drivers for Vista. If that device is USB 2.0, you'll need a USB 2.0 PCMCIA card because the built-in USB ports are only 1.1. You should be aware that this laptop supports only 1 PCMCIA card.
There are other problems with your setup, as the hardware of this system just is not up to running Windows Vista well. First, the graphics hardware does not support the shading instructions and DirectX 9.0+ needed for the "Aero" interface included with the Home Premium version of Vista. Second, Vista might run with only 512MB of RAM (the max this laptop will support), but not well; it really "likes" around 2GB of RAM or more. Third, the BIOS of this system (even the latest and last update) does not support 48-bit LBA (logical block addressing), so it can only "see" hard drives up to 137GB. Any hard drive capacity above that will not be seen by the system, and may result in some drive corruption. At best, you will not have use of the full capacity of that 160GB drive.
Lastly, even if you can get all of the Vista drivers needed for this system's chipset and such to work properly, you will probably not be pleased with this system's inability to run the "Aero" interface, or with the performance limitations when running under Vista. My suggestion would be to remove Vista and install Windows XP. That is what this system was designed for, and all the appropriate drivers are readily available -- possibly including the correct one for your Wireless-B card.
Jan 30, 2011 | Gateway 400SD4 Notebook
Installed windows 7 on my hp tx1000 tablet pc and now no wireless card
wireless card issue is a typical promblem with the Tx1000, first thing is that you changed the operating system and window 7 is unable to pick up the wireless card hardware, and a driver is needed to be installed for the wireless card, which you can find at the Hp site or the broadcom site if you have the broadcom wireless card. Other then that, if nothing works, then try to see if the laptop can locate the wireless card trough the hardware/sound device manager in the control panel. After opening the device manager and scrolling to hardwares and the wireless card is not found, then this is the typical tx1000 wifi mystery promblem. This promblem is associated with the laptop overheating and thus caused the card expansion slot to become defect. This by far is the start of a more promblematic issue that many other tx1000 owner is having. Google "mysterious wifi card on hp tx1000" and there are thousand out there with the same situation.
Nov 04, 2010 | HP Pavilion tx1000z Notebook
The wireless networking on my HP Pavilion laptop suddenly stopped working correctly. I can now only get online via ethernet. When I open up the "Connect to a Network" page, none are displayed. Then when I...
Need to contact the HP Tech Support Number 1-800-474-6836 and checked whether the notebok was under any recall for WLAN Card and if yes and i'm sure it would have expired then Its time to pay $259.99+ taxes and get the Motherboard replaced for you can order Linksys WUSB600N Dual-Band Wireless-N USB Adapter worth $ 79.99 + Taxes to use Wireless Internet efficiently
Aug 18, 2010 | HP Pavilion dv6000z PC Notebook
Importing Pics from SDHC or Compact Flash Card Hangs on Vista PC
you could try updating the drivers.
1. got to hp's website (http://www.hp.com)
2. Click on support and drivers
3. click download drivers and software (and firmware)
4. enter you model number (Pavilion Elite m9400t)
5. select your os (vista 64 bit)
6. download the Fall 2008 Original Intel Matrix Storage Manager Driver
7. install the driver.
Jan 18, 2010 | HP Pavilion Elite m9400t Desktop PC
My wireless connection is not working
Just try to reinstall the drivers of wireless network adapter.You can download the drivers from HP website.
Jun 05, 2009 | Computers & Internet
HP Pavilion dv6000 OS(s)
The product key on the label on the bottom of the laptop will only work for the version of Windows that was installed on that laptop.
You can purchase an upgrade Windows Vista Ultimate and to use in conjunction with the existing Vista Home Premium.
Mar 30, 2009 | HP Computers & Internet
Install vista to hp pavilion dv5 laptop
Make sure the laptop meets or exceeds the resources needed to run Vista. For all versions of Vista, at least a 1 ghz processor or higher, and 20 to 25 GB of free space on the hard drive. Memory: 512 for Vista Home basic, 1GB or higher for Vista Home Premium, Business, or Ultimate. The video in the laptop must be 16 mb or higher. You MUST meet the minimum requirements or the install and startup will fail.
Mar 24, 2009 | Computers & Internet
Computers & Internet Logo
851 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
