Question about Philips SA3285/02 Digital Media Player
Not work sa3285/02 file system error - Philips SA3285/02 Digital Media Player
  • 4 Answers
FORMAT WITH MACINTOSH ¡¡¡¡SOLVE!!!!
In Windows is not recognized
By: Jaime Mora
Posted on Sep 07, 2009
Sim 3 into the future installation
What causes Extended Attributes Are Inconsistent Error Message error? The Extended Attributes Are Inconsistent Error Message error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
How to easily fix Extended Attributes Are Inconsistent Error Message error?
There are two (2) ways to fix Extended Attributes Are Inconsistent Error Message Error:
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Extended Attributes Are Inconsistent Error Message ) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Jan 20, 2014 | Computers & Internet
DHP 301
Many errors surface soon after you install new hardware or software because conflicts often occur between the new product and previously installed components. To put an end to such messages, you might be able to uninstall the program or hardware (and hardware drivers) and then restart your computer to an errorless state.
If you do find that removing a new product eliminates errors, you might have to do some research to figure out the source of the conflict before you can reinstall the new product. Check the manufacturer's Web site for updated drivers, search support areas for known conflicts, and contact technical support for assistance. Sometimes tech support gurus can help you tweak a setting to end software conflicts.
Let it finish. Developing new computing habits can also limit the number of error messages you see. When you first start up your PC, let the hard drive come to a complete stop before starting a task; this lets your computer load all necessary drivers and operating system components necessary for efficient and error-free operation. The same concept works for your other programs. Let each program start up or shut down completely before you move on to another job.
Feb 16, 2008 | D-Link DHP-301 Transceiver
Sim 3 installation
0xc0000005 error
Its a system error.
  • 1st of all update the drivers that control your computer.
  • Scan your computer with an updated antivirus.
  • Use a system utility tool like RegInout to fix corrupt registry and windows files. It will also remove junk files from your computer.
Hope it works for you
Jan 04, 2012 | Microsoft Windows XP Home Edition
Fix error 651 on windows 7
In windows 7, when you try to connect using your PPPoE connections, you may be faced with the following error: Error 651: The Modem (or other connecting device) has reported an error.
These connections would work just fine with Windows XP or Windows Vista PCs.
Again, you are not alone, this seems to be a known bug in Windows 7 that is being worked at. However, you can workaround this problem.
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip). This should help!
Jan 01, 2011 | Computers & Internet
Wireless not working pc told me error 651
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system . If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip)
DO VOTE ME
Dec 07, 2010 | Computers & Internet
Laptop freezes
This can be caused by system file error or your CPU is over heated. I suggest you to have a system check first To check and repair system file error do the following
Right Click on the system disk (c: drive) then Properties > Tools > Errors checking Check now > Tick on "Automatically fix file system error
It will prompt you to schedule the check next time you restart. click YES then restart and let the system have the checking
If this doesnt fix please tell me
Best regards
Dec 05, 2008 | Acer Aspire 5920-6727 Notebook
Error openx menu dat error
Take all the memory contents out to your computer as backup, format your memory to fat32 and put all the memory contents again to the memory from your computer. If not working try downloading the card system files from the card manufacturer site, these files are needed to run the card just like the operative system in your PC, if these files get corrupt or deleted the card wont work.
Mar 30, 2008 | Nintendo DS Lite Console
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
Nov 26, 2007 | Creative Labs MuVo V200 MP3 Player
Philips SA3285/02  Digital Media Player Logo
271 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
