Contributor
- Posted on Mar 14, 2015
Re: Describe in detail how to open up a electro mate 400...
- Unsnap the black plastic tray on the bottom. Turn the unit face down. Loosen four screws along the bottom edge.
- Loosen two screws in the handle and one screw on each side.
- Use flat blade screwdriver to pry up black rubber bumper near the top (back side only) and loosen one screw underneath on each side.
- Open the flat panel, remove any contents and loosen two screws at the back.
- With all 12 screws loosened turn unit face up with bottom toward you and gently pry bottom apart. There are wires and tubes connected inside so just prop it open enough to work.
- Replace battery ($29 + shipping on Amazon, search on battery model like CB19-12 or EXP1218).
- Reassemble.
- Tell spouse you just saved $150; collect reward.
