Question about Troy-Bilt Garden
BELT PLACMENT ON TROY BUILT TILLER MODEL 21A-643B711 SUPER BRONCO CRT
I am assuming your belt broke and you cannot find the replacement.
I had to go to an old timer that owns his independent business and he was able to find a much better belt than the one that came on the tiller. The Belt # is 1916657 and it is 25.5 inches long and 1/2 inches wide. It also has a kevelar core that will stand up to the constant gearing up and down.
Lowes was NO HELP AT ALL!!!!
Hope this at leasst get;s you in the right direction
Posted on Apr 25, 2009
What is the spark plug gap for the engine of a troy bilt super bronco crt tiller
go to troy blit and input model number, this will tell you what you need to know
Jan 22, 2015 | Troy-Bilt Super Bronco 16-inch 208cc...
How do you get the belts off of the super bronco tiller
There is a tennsioner for the belt that you can loosen up to remove the belt. There is a screw that loosens up the belt tensioner.
Good luck.
Jul 27, 2011 | Troy bilt Super Bronco Tiller 208cc
TROYBILT BRONCO REAR TINE TILLER Model#21A643B066...HOW DO I CHANGE MY ENGINE OIL?...WHERE IS THE DRAIN PLUG LOCATED?
The drain plug is generally located on either side of the engine near where the block bolts to the frame of the tiller. It can be a square headed plug or an allen socket head plug.
Feb 12, 2011 | Mtd 21a 643b066 Bronco Rear Tine Tiller
How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Jun 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
How do I change the belts on a troy bilt tiller
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
May 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Changing the drive belt
pull the bracket
Apr 12, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
529 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
