Question about Samsung RS2534 Side by Side Refrigerator
Ice maker water level too high
I have a samsung RS23FGNS and i would like to know how to adjust the water level coming into the ice maker. The ice tray overfills making it impossible for the fridge to break up the cubes.
  • Anonymous Mar 25, 2014
    Recently a puddle appeared underneath. We don't have the ice maker option connected to a water source.
  • Anonymous Mar 26, 2014
    Ice maker supply water line is leaking at back of fridge
    New Friend:
I have a Rs257BARB side by side and need to know how to set the water level to the ice machine.
Posted on May 25, 2013
  • 883 Answers
Generally, there is a screw adjustment for this. usually, turning it clockwise sends more water during fill period (makes period longer). try it and adjust clockwise or counter-clockwise as necessary. Now finding the screw...try prying (or unscrewing) off the plastic cover over what appears to be the ice-maker unit (may also be on back side of frig.
Posted on Sep 17, 2007
  • 2 more comments
  • Marty marty Sep 26, 2007
    ok, so how far did you get on resolving this issue?
  • Marty marty Sep 27, 2007
My Kenmore refrigerator's ice maker is dripping at the front of the ice maker. it drips slowly but makes a big chunk of ice right at the front of the bucket. What should I do?
This is pretty generic without a model # but holds true with alot of them..this type of icicle is usually caused by water overflowing the ice mold of the ice maker module. The reason for the overflow could be that the ice maker module is not level. Check to see if it is tilting. This could be caused by loose screws or a warping of the liner on the side wall of the freezer.
If the ice maker is level, then the next cause could be that the ice maker is overfilling. There is an adjustment screw on the right side of the front of the ice maker module. You may have to remove the cover from the front of the module to access this screw. Turn the screw counterclockwise to decrease the water fill. Turning this screw one turn may decrease the water fill level in the mold enough to prevent the leaking. If not, you may need to make a second adjustment.
Other problems that could cause this icicle could include:
Wicking of the water over the top of the ice maker mold caused by hard water deposits in the mold.
Leaking of the ice maker water solenoid valve.
Crack or leak in the ice maker module.
If the module is level and decreasing the water fill level does not solve your ice maker problem, then I recommend checking the ice mold for hard water deposits. If you find no deposits in the mold (or clean them and still have the same problem), then you will probably need a service technician to fix the ice maker. if you need more help, re-submit your question with additional details.
or reply in comments.
Jan 02, 2018 | Kenmore Refrigerators
How to adjust water fill level to icemaker on LG LMX refrigerator
If it is not on the ice maker unit itself, the machine does not have an adjustment. LG Ice Maker Assembly AEQ36756901
Jun 19, 2016 | LG Refrigerators
My ice freezes as a block when dispensed into ice tray
There are water level adjustment screws behind the plastic cover of the ice maker to adjust the water level when it refills after dumping a tray of ice. When there is to high of a water level it spills over onto the cubes freezing them into a big block. Try to adjust the level of water. There is a arrow which tells you which way to turn the screw to get a smaller fill fixing the problem.
May 04, 2014 | Refrigerators
Ice maker in refrigerator is not making ice properly. ice comes out all together instead of in individual pieces.
your water is to high it can be adjusted but not recomanded also see if your unit is level that may also be a problem with the water.
contact me at www.911servicetoday.com
Dec 30, 2009 | Samsung RF265AA Bottom Freezer French Door...
When I get ice from the ice maker, water comes out.
you may have a real hi water pressure and the ice maker is overflowing tray closing the water supply haft way to reduce the pressure.
ice maker fill up on a preset time and don't stop for water level
there is a way adjust that but is easier this way.
Jul 18, 2009 | Frigidaire PHS38EJSB Stainless Steel Side...
Have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
Unless someone has made a water level adjustment there is,
Only one repair. Replace the ice maker.
If someone has made a water level adjustment you can try this.
Remove the ice maker plastic cover. Locate the water level screw adjust it to a minimum setting and try it there.
If that does not correct the problem, replace the ice maker.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker # S10626636 water level adjustment
IF THE ICE MAKER IS OVERFLOWING, THE ADJUSTMENT SCREW WON'T HELP. ON MODULAR ICE MAKERS, THE BIG
WHITE GEAR ON THE FRONT BEHIND THE COVER HAS CIRCUIT TRACES ON ITS BACKSIDE THAT WILL ARC, BURNING THE PLASTIC GEAR, BRIDGING THE FILL CIRCUIT WITH ANOTHER TRACE, MORE THAN DOUBLING THE FILL TIME. THE MODULE NEEDS TO BE REPLACED. (GEAR IS NOT AVAILABLE BY ITSELF).THE MODULE IS THE SQUARE PLASTIC ASSEMBLY MOUNTED TO THE FRONT OF THE ICE MAKER WITH THREE SCREWS. INCLUDES THE MOTOR.
Mar 27, 2008 | Kenmore 53552 / 53554 / 53559
Small ice cubes The ice maker is not supplying enough water. The result is very small ice cubes. The water supply pressure is on max, can there be a way to adjust the water level? The tray is not even...
The ice maker is time filled, it only has a certain time in which to fill. There is no way to adjust the water level. Check the pressure limiting valve which is in the water line before the filter. Have you replaced the filter? Remove the filter and pressure limiting valve and see if the ice maker receives more water. If it does, then replace the filter and check again. If it is still good, the pressure limiting valve is faulty.
Oct 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung Ice Maker
There is no adjustment for the water level. 9 times out of 10 this problem is with the electric water valve itself. It is not opening all the way, and since the amount of water that is allowed into the ice maker is on a time control, the tray is not filling properly. A new water valve should fix the problem. Not very difficult to install. Shouldn't cost more than $25.00 from an appliance parts store. Good luck, dfink
Sep 17, 2007 | Refrigerators
Samsung RS2534 Side by Side Refrigerator Logo
1,286 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
