Question about HP (D7580-60003) Motherboard
Demension 8300 no power up
I aquired a dell demension 8300 i know nuthing of it but just tryed to fire it up and nuthing but light on front panel and fans and led on motherbourd is on and no diagnostics lights on back light up at all
  • muell722 Apr 18, 2009
    hey i took the dell psu out and stuck it in another one ane it works just fine what else can it be bad cpu mabe?????
  • HP Master
  • 5,660 Answers
All you have to do is replace the power supply, and the computer will come on. What has transpired, is the power supply went out, and the people you received the computer from, didn't know that. Too bad, as this is a cheap fix, and easy to do.
Do you have another desktop computer, that you can borrow a power supply out of for a test?
The Dimension 8300 uses the standard ATX power supply, that about 98% of computers out there do.
The Dell Dimension 8300 uses a Pentium 4 processor.
Uses either DDR Sdram at 333MHz (PC2700) or DDR Sdram at 400MHz (PC3200)
Maximum TOTAL Amount of ram is 4GB
Maximum Amount for EACH ram slot is 1GB.
Motherboard chipset is Intel 875P
Has an AGP 8X slot for a graphics card. (Remember that it's AGP 8X. This is the best version of the AGP style graphics cards. They still sell them)
Has four PCI slots.
Uses an IDE harddrive. (IDE is also referred to as EIDE, ATA, and PATA)
Has either a 250 Watt power supply, or a 305 Watt power supply. Back when this computer was made, power supply's actually only put out 70 percent, of the stated maximum wattage. Not the computer manufacturers fault, it was the power supply manufacturer. (The power supply's are made by somebody else, just like all the parts are for a pre-built computer) The power supply manufacturer had the tendency to 'fudge' the Wattage rating up a little. Made the power supply look better.
http://support.dell.com/support/edocs/systems/dim8300/sm/specs.htm
A computer will only use the power it needs, and no more. I don't care if you put a 10,000 Watt (Exaggeration. They don't make them for a personal computer) power supply in your computer,
if it only needs 100 Watts, it only uses 100 Watts. (Like surfing the internet)
I recommend this $30, reliable, decent power supply. It's a 350 Watt unit,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3255390&CatId=106
How to install a power supply,
http://support.gateway.com/support/manlib/cmponts/Process/8508750/08750c01.htm
(From Gateway.com/Support)
Posted on Apr 17, 2009
  • joecoolvette
    joecoolvette Apr 18, 2009
    Could be a Cpu. That one got me, I must admit! Thought sure it was the Psu by the symptoms. Just for fun, do you have any ram sticks that are good, that you can stick in it? Compatible ram sticks. Either
    PC2700 or PC3200. Just one ram stick for a test. Put it in Slot 1.
    (Sometimes printed on the mobo as DIMM 1)
    Then see if you have a compatible Cpu. Past that point it's the mobo itself. (Motherboard)
I hope some one can help me. I have an old Dell demension 8300 desktop. just recently I had a problem where the system stopped responding during a program load. even Ctl Alt Del was non responsive. So I...
You may have a electronic problem.
could you open the computer and look at the CPU. Around the CPU are little canisters called capacitors. the tops of these capacitor are rounded,means you need to replace them.
they are about 8-10 of them, it is a $5.00 fix and it works well after that
Aug 05, 2010 | Dell Dimension 8300 PC Desktop
DELL Demension 8300 PC, cannot boot from cd rom
try ubuntu which is a good version of linux,search on google..Now if you really want to install another o/s then you need to change BIOS setting to boot from cd first on start up screen.For most pcs it;s normally a delete or F2 button but hace a look at boot up it will say something like press del or F2 to change...
Jun 22, 2009 | Computers & Internet
Dell demension 8300 pc
make sure boot sequence is cd-rom first and possibly disable hd
Jun 22, 2009 | Dell Dimension 8300 PC Desktop
Dell Demension XPS B866 N232 motherboard power pin assignments
dont take any risk with power supply. purchase a new compatible power supply to solve your prob...
good luck
shafyk
Jun 12, 2009 | Intel Motherboard
How do I remove the power button on Dell Dimension 8300 desktop
open the side- and along the just inside the front exposed edge there are several tab that get push inward to release the front. They have a tendency to catch again when you go to the next one...you'll just have to play with it a bit. once that is open you'll see the other little plastic tab that holds the switch assembly . Don't forget to UNPLUG the power supply.
May 14, 2009 | Dell Dimension 8300 PC Desktop
Dell Demension C521. Dead! Nothing! Even the little led light on the motherboard.
This is most likely caused by a power supply failure. If you have or know someone who has another power supply you could use for testing thats where you'll want to start.
Hope this helps.
Mary
May 09, 2009 | Dell Dimension C521 PC Desktop
Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Aug 08, 2008 | Dell Dimension 8300 PC Desktop
HP (D7580-60003) Motherboard Logo
222 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
