Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Discrete code for toshiba LCD TVs, power on and power off
I need the discrete ir code for power on and power off for the latest toshiba LCD TVs (32")
2 Suggested Answers
  • 10 Answers
SOURCE: Discrete IR code for Current model Toshiba 32" TV
these only work on the latest models HX81 etc...
pon- 0000 0069 0022 0002 0161 00b1 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0609 0161 0058 0016 00b1
pof-
0000 0069 0022 0002 0161 00b1 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0609 0161 0058 0016 00b1
Posted on Jun 29, 2009
I need the wiring diagram for the 2006 chevy avalanche ignition
http://www.bbbind.com/free_tsb.html free wiring diagrams . Ignition switch or ignition system - coils , plugs , wires etc... .
Everything on your vehicle is electronically controlled by the BCM - body control module .
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the body control module (BCM). The BCM uses 3 signals from the ignition switch. These are the Ignition 0, Ignition 1, and Accessory.
Discrete Ignition Signals
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Your best bet , take it to a qualified repair shop !
May 10, 2017 | Cars & Trucks
I had a locked car light come on in my 2006 chevy malibu, it no longer will drive. doesnt turn off, goes in reverse but when in drive, just revs like the car is in neutral, why?
The lock an car symbol is for the anti-theft system ! By not turning off, do you mean you can't turn the key to the off position or you can turn the key to off but the car won't shut off ?
It sounds like you have a Power Mode Mismatch
The ignition switch is an input to the BCM - body control module an if something happens to the system , the BCM will keep the vehicle in the last known mode Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the power mode master (PMM) fail to send a power mode message. The fail-safe plan covers those modules, using exclusively serial data control of power mode, as well as those modules with discrete ignition signal inputs.
You could have an ignition switch problem or something wrong with the BCM .
Discrete Ignition Signals Those modules that have discrete ignition signal inputs, also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, battery positive voltage, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 volts, the modules will fail-safe to OFF-AWAKE. In this state, the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
This is one you need to take to the dealer because they have a factory scan tool !
Aug 03, 2015 | 2006 Chevrolet Malibu
Panasonic PT-AE8000U discrete codes
go to www. remotecodelist.com and download for free.
God bless you
Nov 29, 2013 | Televison & Video
03 grand am powers up "lights,radio,etc.turn the key nothing
Why would you do 10 minute key trick ? Is the SECURITY light on steady ? Just a code reader ? Checks just Engine PCM codes ! Need a professional type scan tool to check codes in the BCM - body control module ! Don't know what and how much you know about these GM vehicles ? The ignition switch is a low voltage input to the BCM ! To determine power mode , off ,ACC , run , crank
On vehicles that have several control modules connected by serial data circuits, one module is the Power Mode Master, PMM. On this vehicle the PMM is the BCM. The PMM receives 3 discreet ignition switch signals to differentiate which power mode will be sent over the Class 2 Serial Data circuit.
To determine the correct power mode the PMM uses the following circuits:
• Ignition 0
• Ignition 1 voltage
• Ignition 3 voltage
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, battery positive voltage, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle . If you don't know anything about this your best bet , take it to a GM dealer . Without knowing what state the BCM is in or seeing from the ignition switch or if DTC'S - diagnostic trouble codes are stored , can't give you any sound advice . Would only be guessing !
May 31, 2017 | 2003 Pontiac Grand Am
Looking for discrete codes for a Insignia NS-L55X-10A. Are there any?
No discrete codes directly. They are manufactured by LG so a lot of times LG discrete codes will work.
YMMV.
Mar 01, 2011 | Insignia Televison & Video
I would like at published discrete code list for a Samsung UN55C800XF TV to program into my Universal Remote MX-700.
Hi.
Your TV is an LCD TV, I do not know if discrete codes are different from ones published for previous model. Codes for this specific model are not yet available on the web, but codes for previous model will probably work (see here).
Codes:
HDTV Televisions (4)
HLN Series HDTVs (14)
HLP Series HDTVs (14)
HLR Series HDTVs (9)
HLS Series HDTVs (21)
HLT Series HDTVs (21)
Have also a look at this thread.
Jul 26, 2010 | Televison & Video
I would like to set the clock on my sanyo 32
The easiest way is some sort of automation system like Crestron or RTI with an astronomical clock and IR capabilities.
You could easily add a timer to the outlet but that will only take the TV from all off to standby. To turn it on you have to send the IR command for power. Also, I doubt the Sanyo has discrete codes for power which will make this impossible to make reliable because if the TV is on at the time you have the automatic power ON it will turn the TV off.
If you really have to do this, here are the parts:
RTI XP8 RTI VS1 Niles MF1 Programming software and a programmer
Nov 24, 2009 | Sanyo DP32648 32 in. LCD TV
What is the yamaha htr 6050 remote code?
You have to "learn" the IR. Yamaha has discrete on and off commands. which universal remote are you using?
Jul 25, 2009 | Yamaha RX-V563 Receiver
Unable to detect lcd
Replace the Discrete Video card. That's why your LCD didn't detect when you run the Diagnostic test. There 2 type of video cards available to Dell Inspiron 6400/E1505. Either you have a on-board video card or discrete video card. Mostly, the discrete video card is caused when you not getting video output to your LCD (completely dark as if it is off). Discrete video card is detachable and replaceable. Good Luck.
May 16, 2009 | Dell Inspiron 6400 Notebook
pof-
Apr 18, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
231 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
