I ve updated my BIOS 64 bit Vista and after it shutdowns my computer I have asked for a BIOS password that i hve never set :S
How can i remove this password?
I saw a forum gives solutions about it but coudnt see my model there.
http://www.laptop-repair.info/toshiba_b ... sword.html
There is a screen shot from My notebook of Wireless cover.
[URL=http://img524.imageshack.us/my.php?image=toshibaa215s4747.jpg][IMG]http://img524.imageshack.us/img524/3217/toshibaa215s4747.jpg[/IMG][/URL]
Under de memory have a pin J4 link to ground when notebook is off for 5 seconds,its clear cmos hehehehe
www.niteroinotebook.com.br
sorry my english
This worked for my Toshiba Satellite A215 S4747 laptop. I removed the battery, pressed the power button for about a minute to deplete any power, removed memory modules, located J4 pin and pressed a tiny flat head screwdriver on it for 35 seconds. replaced memory and battery and booted. I then ran a repair when presented the option.
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
fuatm16 I have same problem with bios password
How you fix this in the end?
