The pc did not turn on
I have foxconn motherboard and when o press on the power the fan start for one second then it turn off and then if i press on the power their is nothing will happen until i unplug the power cable then back it then press power bottom the fan will again turn for one second i have foxconn via chip p4 800 cpu : 3000/512 i change the power supple and the problem is still i change the ram to but problem still
  • Anonymous Apr 17, 2009
    i remove all ide cd and sata problem still
  • 3 Answers
It looks like your HDD or ROM has problem. Mostly your Hard Disk must have failed.
Posted on Apr 17, 2009
No display after restart
bro I am having the same problem!! after searching I found that the pc gets display on my case if I remove power cord and press the power button (and holds on) of pc like 30 seconds and then reconnect the power cord and powers on!! this is how I get back display after restarting pc.
Feb 02, 2010 | Foxconn 45CMX socket LGA775 motherboard...
I have a foxconn p4m800p7ma motherboard everything is connected but it will only blink the lights twice when i hit the ON switch and the cpu fan spins for a second then stops.is this a dead motherboard?or...
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a Dead Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Dec 19, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Desktop PC turns off everytime it is turned on
Ok, let's try to eleimate some things. When it shuts off do you here a click first? This may indicate the hard drive is going bad. How long does it take to shut off if it was the first time in the morning that you turned it on? How long before the second time? Etc? What we're trying to determine here is is this heat related? If so then the power supply or mother board could be the culprit. If you turn it on (first thing in the morning) and immediately go into Safe mode (F8) how long does it take to shut off? If you turn it on (first thing in the morning) and immediately go into BIOS or Setup, how long does it take to shut off? If you press Start, Control Panel, Administrative Tools, Event Viewer and System. Do you see itms that have a red X through them? Email me back and we'll continue with your results.
Apr 01, 2009 | Foxconn 661FXME Motherboard
Could a faulty fan cause my pc not to switch on
Normally the computer will still come on even if the fan is not there but then will sometime display cpu fan warning and then sometimes turn off depending on motherboard and so on but unless the fan wires are shorted out or something this is most likely not the case
It sounds like your power supply has gone bad
Do you hear any type of winning sound or like a discharge sound that is barely noticeable when you turn it on? You would probably almost have to put your ear right next to it to hear it or listen carefully when you press power because that sound is one of the capacitors in the power supply that has gone bad and the power supply would need to be replaced
Do you have another power supply you can use to see if it works with a different one?
Nov 25, 2008 | Intel Foxconn: Foxconn CPU Cooler For P4...
Foxconn motherboard 650m02-g-6l error signal
I would recommend buying a new stick of RAM at your local store. If it does not work, as long as it is not damaged, most places will take it back without a restocking fee. If it does work, then your good to go!
If it does not work, then there may be a problem with the actual RAM slot on the motherboard,
Sep 03, 2008 | Foxconn 650M02-G-6L Motherboard
Foxconn 760GX K8MC-S
Hi...
You already have done your best and yet it still does not work... Same problem I have last week... but I have changed the motherboard with anew one and it worked perfectly again... That is I had to break my piggy bank.
Sorry my friend...
Jun 17, 2008 | Foxconn 760GXK8MC-S Motherboard
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
