Question about Panasonic CQ-VD7001U Car DVD Player
HELP PLEASE I WIRED THE RADIO UP AND I AM ONLY GETTING SOUND THROUGH THE LEFT REAR SPEAKER. THI IS NOT MY FIRST TIME TO WIRE UP A RADIO. I WAS JUST THINKING THAT IT MIGHT BE SOMETHING INTERNAL IN THE RADIO
  • 150 Answers
I would rip apart your harness and re-wire it just to make sure it's not bad wiring. The speaker connections are white/gray/green/purple. White and gray are front and green and purple are rear. It is possible the the output of the head unit went, but you can't be sure until you rule out the wiring possibility. L8R Good Luck
Posted on Sep 16, 2007
SOURCE:
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
I HAVE TWO YELLOW WIRED POWER AN WHAT..95 CAMARO REWIRING RADIO
Below is a listing of the radio wires and what they control.
1995 Chevrolet Camaro car radio wiring schematic
Car Radio Battery Constant 12 volt Wire: Orange
Car Radio Accessory Switched 12 volt Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Left Front Speaker Positive Wire: Tan
Left Front Speaker Negative Wire: Gray
Right Front Speaker Positive Wire: Light Green
Right Front Speaker Negative Wire: Dark Green
Car Audio Rear Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire: Yellow
Left Rear Speaker Negative Wire: Brown
Right Rear Speaker Positive Wire: Dark Blue
Right Rear Speaker Negative Wire: Light Blue
Jul 08, 2014 | 1995 Chevrolet Camaro
I have a 1991 ford festiva i changed my radio and now my shifter and my dash lits dont work are they wired in with the factery radio
Hi, the factory radio uses the illumination wire, but the aftermarket radio does not. You have to make sure that wire is taped off so it doesn't short the illumination circuit. Check your tail lights fuse. If it's blown, pull the head unit and disconnect/tape off the illumination wire (blue with a white stripe) from the factory harness. Then put in a fresh fuse. If you have more questions, please specify the model of the head unit.
1991 Ford Festiva Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Red/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/White
Left Front Speaker Positive Wire (+): Blue/Red
Left Front Speaker Negative Wire (-): Blue/Yellow
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): Blue/White
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
Nov 21, 2011 | Car Audio & Video
I have a 1990 Celica, trying to put in new radio. Got everything wired up correctly, Constant - blue/yellow, acc - gray, ground - brown and it won't come on. Radio fuse (top center 15 amp) is good,...
You have it right. Use a 12 volt test light to see if there is power between the gray and brown wires when the key is on. If there is power there, you may have got hold of a bad radio.
1990 Toyota Celica Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow, connects to yellow
Radio Switched 12V+ Wire: Gray, connects to red
Radio Ground Wire: Brown, connects to black
Radio Illumination Wire: Green, do not use
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Oct 29, 2011 | 1990 Toyota Celica
PANEL/CLUSTER LIGHTS HAS GONE OUT AFTER REPLACING RADIO. WHAT MAY HAVE CAUSED THIS PROBLEM AND HOW CAN I SOLVE?
radio may have been wired improperly or fuse may have blown. First check fuses. Below is the color scheme for your radio wiring. The dimmer wire is White with a green stripe. This wire should be connected to the orange wire of your aftermarket stereo. If you have an unusual stereo, leave the factory wire unhooked (and insulated) until you can verify which wire on your stereo is for the light. Let me knoiw if you have questions.
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2?
Front Speaker Location: Doors
Right Front Speaker Wire (+): Green
Rear Speaker Size: 6? x 9?
Rear Speaker Location: Rear Deck
Oct 20, 2010 | 2000 Toyota Camry
Radio wiring diagram for 94 dodge dakota
1994 Dodge Dakota Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Violet/White
Right Front Speaker Negative Wire (-): Brown/Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Red
Right Rear Speaker Negative Wire (-): Blue/Red
This should help and thank you for using Fixya.
Mar 06, 2010 | 1994 Dodge Dakota Club Cab
91 Ford Tempo - New stereo won't work ... Please HELP
here is the radio's wire color diagram, u should be able to fix the problem with this info.Fuse box is on drivers side under the dash.
1991 Ford Tempo Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Audio Front Speakers Size: 6 1/2′
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Apr 12, 2009 | 1991 Ford Tempo 4 Door
Japanese import integra type r stereo wiring diagram
Try the following, this is an 1997 USA Integra
Radio Constant Wire 12V+: Blue/White
Radio Switched Wire 12V+: Yellow/Red
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Left Rear
Front Speakers Size and Location: 5 1/4′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Front Speakers Size and Location: 6 1/2′ Side Panels
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Oct 06, 2008 | 1997 Honda Accord
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Sep 29, 2008 | 1996 Ford Explorer
Panasonic CQ-VD7001U Car DVD Player Logo
74 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
