Question about Kenmore Elite 45986 Front Load Washer
Washer door seal is loose
While washing clothers I heard a loud squeeking noise. I turn off the washer and notice that a shirt sleeve had twisted inside the door seal and it became loose with the round ring off of it. It is a Kenmore HE2Plus front loader. Could you tell me how to put the seal on correctly to the drum and where does the ring go? Thank you!
  • 2 more comments
  • ketner Sep 19, 2007
    Thank you very much!!!
  • patty97404 Dec 16, 2008
    I have the same problem but need clarification on exactly where the ring goes?
  • Anonymous Mar 16, 2014
    The drum has pulled away from the door seal. There is a finger-width gap between the drum and the seal.
  • Anonymous Mar 22, 2014
    Drum and door seal affected
  • 5,911 Answers
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Posted on Sep 16, 2007
SOURCE:
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Hotpoint ultime wt640 has a slight squeek seem to be on front around door area had top off and turned drum motor and drum seem fine and springs ok
Remove rear cover of washer, remove drum belt,and from front of washer, spin drum by hand.
There should be no noticeable noise.
If you can still hear sqeek, then it could be a drum bearing that is dry or starting to fail. or the drum is rubbing on the front of the door seal
You should be able to detect what it is this way.
Please rate my solution.
Thankyou.
Jan 17, 2010 | Hotpoint Aquarius WD640 Front Load...
Rubber door seal has disconnected
if the wire in the seal is propely positioned and not slightly askew it should work OK But if it looks correct and leaks you will need a njew seal as it may have been bent or stretched
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WM won't spin after sleeve got caught in door
I had this happen. The drive belt had come off. Just take off the bottom panel from the back and reattach the belt.
Jan 27, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Maytag Neptune 9700 series
IT SOUNDS LIKE THE OUTER BAND TO HOLD ON THE DOOR BOOT/SEAL. WHAT I HAVE SEEN IS THAT AN ARTICLE OF CLOTHES WAS NOT ALL THE WAY INTO THE WASHER AND IT WAS STARTED, PULLING THE DOOR BOOT INTO THE WASHER. THE ONLY OTHER THING I HAVE NOTICED WITH THIS NEW BREED OF SUPER CAPACITY WASHERS IS THAT THEY LIKE BIGGER LOADS TO HELP BALANCE THEMSELVES. IT MAY BE POSSIBLE THAT IT WAS SO SEVERLY OUT OF BALANCE THAT IT PULLED THE BOOT INTO THE TUB AS THE MAYTAGS OF THAT MODEL LINE WERE KNOWN TO NOT BE THE MOST SENSITIVE TO OUT OF BALANCE CONDITIONS. THERE IS A CONTROL BOARD KIT THAT COMES WITH A MOTION SENSOR NOW FOR THEM AS AN UPGRADE.
Jan 27, 2009 | Maytag Neptune MAH9700 Front Load Washer
Front Load Washer Seal
you will have to take off the front off washer to put it back correctly.
remove the top panel 3 screws in top rear
remove the bottom panel 3 screw in bottom front
remove the top led control panel 3 screw or more along front lip
if you disconnect any wiring mark it well .
now the front of washer can be removed with or without the door (your choice)
careful with the door lock wiring.
be sure to unplug the washer.
while you are in the innards its a good time to wipe around the drum any buildup of soap etc..
and to clean the filter trap in the bottom access tube below drum.
Mar 31, 2008 | Maytag EPIC MFW9600S
Clothes got tangled with rubber seal inside and ripped it. How do I fix/get a new seal?
This part is a problem on many front-loaders and never really goes away. The rubber seal is a replaceable part and should be supplied under warranty. There is no way to fix it.You should try very hard to get Sears to pick up the labor cost as well.
Mar 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washer won't spin anymore
Was it getting loud in spin prior to this?
If so, based on past experience with this model, I would say you need at least a triple lip seal, belt and possibly a transmission.
Nov 22, 2007 | Maytag SAV2655A Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
445 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
