Question about Samsung Digimax S800 Digital Camera
Samsung S800 Lens dont come Out hellP !
Ok so i got this camera donno about 1 year ... Suddenly i noticed that it comes out hard , then next day more badly , and later a weak ago it is jammed inside i bearly can take it off with my finger nails donno wath is wrong it worked verry good , also the video quality is worse then the S700 , the S700 has 7.1 mpx and S800 has 8.1 donno this camera is verry bad :|
  • Anonymous Nov 04, 2007
    When I try to turn on the camera by the power button, It gives three beeps and the lens doesn't move. The batteries are new from the pack and three beeps are the noise that the camera makes when the lens is being obstructed
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Posted on Feb 11, 2013
SOURCE:
SOURCE: Samsung S800
I have the same problem Having forced the lens out, it retracts when I power off and back to square one. My solution is to force the lens out (was horrible grating sound) and then power off by opening the battery door. The lens stays out when you power on again and it still takes good pictures. Not ideal but better than a new camera.
Posted on Jul 13, 2008
tazdev
  • 75 Answers
SOURCE: my samsung digimax s800 stopped
Try to replace the battery with rechargeable ones.
And if that doesnt work, call 1-800-SAMSUNG and have your camera sent for service.
Posted on Jan 19, 2009
  • 6 Answers
SOURCE: my samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
Posted on Feb 24, 2009
  • 17 Answers
SOURCE: my samsung L830 camera has jammed with the lens open and
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730.
Posted on Aug 01, 2009
  • 11967 Answers
SOURCE: samsung pl50 digital camera wont open lens cover or come on
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 31, 2010
On my Samsung Digimax S800, when I put the memory card in, it says to check sd card. What do I do about it?
When the card worked before, check if you did not switch the lock switch down. And check all contacts on the card and in the camera. They should be clean and shiny.
When you recently bought a new card you could have bough a SDHC card and these won't work in your S800.
The S800 only accepts MMC and SD cards, The SDHC and SDXC cards won't work.
A few years ago you still could buy 4 Gbyte SD cards. Now even most 1 Gbyte and 2 Gbyte cards are already SDHC. SDHC was introduced at least 7 or 8 years ago, so all new devices accept SDHC. The SDXC was introduced at least 4 years ago, so in a couple of years, you perhaps only can buy these cards?
Feb 21, 2015 | Samsung Digimax S800 Digital Camera
My s800 camera wont turn on or it does but the zoom/lens is stuck and wont come out-it then has 3 beeps and turns off
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 20, 2011 | Samsung Digimax S800 Digital Camera
My S800 has been amazing, however since Thursday when I take a pic and zoom in, the image is very bright, or white and has lines all over it (looks like a bad canvass painting, non zoomed images are fine!...
Hi, the problem is in the shutter that you can found inside of the lens unit and maybe the shutter not work properly or damage. you will notice also once you take picture during night time the pictue is good but if you zoom in you will find the lines all over the picture.
tryo to open your camera and check the lens unit. First try to disconnect the the lens cable and connect then check. if the problem still occur, you need to do is open the lens unit and adjust the shutter if working fine or not.also check the flat cable if its not broken.
if you can't do this bring to service center
goodluck and thank you my friend
Jul 17, 2010 | Samsung Digimax S800 Digital Camera
Digimax S800 Samsung : Lens won't retract
check first if battery is ok, maybe your problem is your barrel, if barrel not function properly you need to change motor or barrel allignment. if barrel is ok you have short circuit in your assy pcb main.
Apr 23, 2010 | Samsung Digimax S800 Digital Camera
S800 lens won't close, can't take photos
The lens was bent to one side, so bump with my palm to straighten it back. I was able to start using my Samsung again.
Mar 21, 2009 | Samsung Digimax 800K Digital Camera
Samsung digimax s800 not swiching on
The problem is that the lens is jammed. I had to take my camera apart to unjam mine manually, the cogs that move the lens are not lined up with each other, thats why you hear the motor turning and then you get the 3 beeps because the lens hasnt initialised
Dec 20, 2008 | Samsung Digimax S800 Digital Camera
My samsung digimax s800 won't turn on,the batterys are ok
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
Camera Samsung S800
return to store or samsung quick - it's a know power issue mine started like that and now its outta warrany it burn thru 2 batteries in a day lets me open lens and maybe take 1 pix
Nov 06, 2007 | Samsung Digimax S800 Digital Camera
3 beeps and nothing else
just three months old?- return it to the Vendor for replacement and get onto the Samsung Tech support Team
Jul 10, 2007 | Samsung Digimax S800 Digital Camera
Samsung Digimax S800 Digital Camera Logo
70 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
