Question about Gateway M305CRV Notebook
Replacing dvd/cd-rom drive on gateway laptop
Does anyone know how to replace the existing cd drive with a cd/dvd rom drive on a gateway laptop?
  • 3 more comments
  • Mark1980 Mar 18, 2008
    I have a Gaetway laptop Model MX6442, Model #MA3. My kids broke the CD drive, the door does not open and when I open it with poking thru the little hole, it hard to close. Can I replace the CD drive. Thanks
  • Anonymous Oct 09, 2008
    I have a Gateway P172X laptop whose dvd door will not open. I have gone through the Computer (right click on E drive and select Eject) and tried hitting the button on the outside of the DVD door. The dvd spins once but does not open. Poking a paper clip into the hole does not work. Also I tried to uninstall the DVD drives and rebooting. Original configuration and problem back on reboot.
  • arcbcc777 Dec 06, 2008
    How do I replace the DVD/CD drive on my Gateway MX6446 laptop?
  • danetta_barn Mar 04, 2009
    the dvd/dd rom drive door will not open.
  • Yacob Hickman
    Yacob Hickman Nov 25, 2013
    I Have a LT4010u, its a pretty small laptop and i need to know what brand of dvd disc drive i need to work in harmany with my laptop, if the brand doesnt matter ok, if it does witch one?
    Novelist:
  • 188 Answers
Depends - what gateway? the one you listed under?? Because the model you posted with already came with a DVD drive.
Reply with the model of your machine and i can probably find you help. Gateway usually has instructions on their site.
The instructions for the M305CRV are here.
That model can use pretty much any standard laptop CD if you dont mind the face not matching get a generic drive like the Sony CRX880a at
http://www.directron.com/slimoptical.html
Posted on Dec 28, 2007
SOURCE:
AM USING A GATEWAY LAPTOP WITH OPTIARC DVD RW AD7640S ATA. IT WAS WORKING INITIALLY BUT FOR SOMETIME NOW WHEN I INSERT ANY CD, IT TELL ME TO INSERT A CD INTO THE DEVICE EVEN THOUGH ITS INSIDE. AM USING...
2 possible issues....1 driver for the dvd rom is corrupt.....try using the cd the unit came with and re-installing the driver....2 bad rom....if your under warranty...try just sending the rom in....if now...flip over the laptop....find the 1 screw that will let you slide out the rom...look for the part number/ model number....find one on ebay....real cheap there...usually under 10 bucks....try cc.texas.smart.shop (member) that is me and i have a few gateway roms avail.
Oct 12, 2010 | Gateway (5500652) (  5500652)...
Gateway 450ROG, will not start. Red DVD/CD ROM
I have the very same problem, the Drive light turns red, the screen is "black" and the battery charging light indicator on the front is off. No differance if I'm traying to power up on battery or AC-adapter.
Before this problem appeared I had problems where the laptop was powering off, with no warning, and I had to restart it. This happened several times and was going on for about a week before it died totally. Can it be the CMOS battery on the mother board? Anyone having clue what the problem could be?
Mar 31, 2010 | Gateway 450ROG Notebook
Need to install a new CD/DVD drive in a Gateway Laptop model 7110GX Does anyone have info on how to do this plus recommendations for a replacement drive for this model. Thanks, Bill
Here's a direct link to the service manual for this laptop:
http://support.gateway.com/s/Manuals/Mobile/8511184.pdf
On page 36 of this manual, you will find details on how to replace the CD/DVD drive.
Oct 22, 2009 | Gateway 7110GX PC Notebook
I can't insert any cd's.
Maybe the laser eye is jammed. It tracks back and forth reading data from the disc.
You may either replace the drive or have it repaired.
I had one on my PC do the same vibrating, clicking noise. It only cost 40.00 to replace.
But for a laptop, you're looking between 60-100 dollars to replace.
You can see how much it would cost to repair first, but my guess is it would be cheaper to replace.
Jul 12, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Cd rom drive not working, will not read discs
If it will not read anything and doesn't spin up then it's time to replace it.
Here's one on ebay that should work for you...
http://cgi.ebay.com/GATEWAY-4000-4028-4520-DVD-CD-RW-COMBO-DRIVE_W0QQitemZ170320375444QQcmdZViewItemQQimsxZ20090412?IMSfp=TL090412151007r16432
This is not my auction....I live in Missouri.
Apr 26, 2009 | Gateway 4028GZ Notebook
My cd rom drive will not recognize any cds or dvds. When I put a disc into the drive it will tell me to insert a blank disc into the drive. I have tried over ten different discs (including the one that...
what do you mean not recognized? not detecting the drive or not reading? if not recognized by windows you can check the driver for drives in the windows if not reading it is the lens problem..if the lens problem, the solution only is to replace the lens or to replace the whole drive
Mar 07, 2009 | Computers & Internet
Gateway M505 internal cd-rom slot does not take in a cd dvd
Not unless you know A LOT about electronics. It's best to just remove the drive and buy a replacement on ebay.
You can either search for M505 drive
or use the part numbers from the drive if you want an exact replacement.
Best of luck!
Feb 25, 2009 | Gateway M505 Notebook
Without knowing your specific laptop, look underneath about 5 inches from the edge where the drives slides in. You should see a screw there but not holding a panel.
Remove that one screw, pop the drive open and give it a gentle pull, it should just slide out.
Most laptop drives are the same with the exception of the faceplate and the bracket (surround) that is attached to the bare drive.
This is removable and can be transferred to another drive. Careful not to lose any of those tiny screws =)
Apr 09, 2008 | HP Pavilion dv6000z Notebook
Removing the DVD-ROM drive
hi the removel of the dvd drive is easy as taking out the battry 1. Remove the battery from the bottom of the laptop 2. Make sure the laptop is NOT plugged in. 3. There is a release button for the CD/DVD ROM drive on the bottom of the laptop, simply press and hold the release switch and pull the CD/DVD drive out. replace it with your new 1 good luck
Apr 06, 2006 | Toshiba Satellite Pro A10 Notebook
Gateway M305CRV Notebook Logo
5,598 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
