Question about Netopia 3346N-VGx Router (3346NVGX)
Facing No lights at all on router.
Firstly bought was fine and running well. after a day or 2 when switched on the router doesnt show any lights at all. what might be the problem? plugs and cables are already intact and fine. please assist thanks
    Problem Solver:
  • 11 Answers
How long ago was it purchased? No lights at all would certainly seem to be a power cord issue. There's a possibility there may have been a surge that fried out the router, or the power cord may not be putting out the correct (or any) voltage anymore, but to check that you'd need a voltmeter. Have you tried plugging it into a different outlet to see if that makes a difference?
Posted on Sep 22, 2007
SOURCE:
Ips sensotouch 3d razor handle has just stopped working for no reason, 1 min it worked the next it doesnt
You may want to try another category, this one is for Routers. As in Internet.
Apr 17, 2013 | Computers & Internet
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
My linksys router doesnt have a default gateway and the reset buttton on the router doesnt work either
When you look between the Ethernet port and Power button, there should be a reset button there you should hold for 5 seconds. Of course if you do that, If you changed Network name and key that will be reset to the default settings, Also is wireless network showing when you pull up the Networks? You can leave user name blank, but default password is admin. Also email me with more info I will be glad to help
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&app=vw&vw=1&login=1&json=1&docid=1e97db4854604b0fb5cc8c0d74491e35_19584.xml
Dec 26, 2011 | Linksys WRT54G3G Wireless Router...
One computer connected the other limited or no connectivity
When using a router your IP is assigned to your Router. Then Your router assigns IP's to whatever is hooked up to it. Set everthing to detect automaticly. Might delet connection and create a new one.
Mar 11, 2009 | SMC Netgear 5Port Gigabit Ethernet Switch...
No Connecton with wireless computer
it just means tat the connection is secure
wat you could try would be
1) take out power for modem then dynex router
2) power the modem n then router
3) if this doesnt work you would have to redo the wireless setting on the computer
Dec 23, 2008 | Linksys Wireless-G WRT54GS Router...
No light
Try resetting the router and starting again as a first step.
Locate the reset button on the back and hold for 30 secs (you may need a pin as it is tiny)
If that doesnt fix, ring Belkin as its may be faulty.
:0) x
Jun 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-link 524 looses conection
check the timeout when idle settings on the router. you need to set it to 0 for never break the connection.
other options are to upgrade the firmware of the router.
you should also isolate the problem by connecting the pc directly to the modem to make sure the same problem doesnt occur. if it does then contact your isp.
good luck
smeags.
Dec 31, 2007 | D-Link AirPlus DI-524 Wireless Router
Not working No lights.
is that a brand new router? if so, bring it back first to the store where u brought it...
Sep 16, 2007 | Netopia 3346N-ENT Router (3346NENT)
Light is not on..
I'm facing the same problem with my plantronics 510. Would love to hear if it is fixable. I've already bought myself a new one (tip - look at craigslist for a cheaper deal than even ebay and amazon)
Aug 02, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Open Questions:
See all Netopia 3346N-VGx Router (3346NVGX) Questions
Netopia 3346N-VGx Router (3346NVGX) Logo
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Ekse
Thomas F. Schneider
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
