Question about Canon PIXMA MX310 All-In-One Printer
My Canon MX310 draws the paper in awry
Feeding the paper the Canon MX310 draws the paper in unconstantly.
  • jblignaut Apr 24, 2009
    The MX310 draws the bottom of paper in towards the right (viewed standing in front of the printer). At times it so bad that the ink is smudged accross the paper.
yooperbud
  • 8637 Answers
SOURCE: canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
  • 298 Answers
SOURCE: paper feeder isnt ligned up in the middle canon mx310
There is some kind of mechanical lock on it. Push, Pull, Tip or Slide to correct position. It is only plastig. Look under and behind it to figure it out.
Posted on Mar 26, 2009
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
dmbgo
  • 58 Answers
SOURCE: Canon Pixma MX310: misfeeds
Hi Paper misfeeds are normally caused by something obstructing the paper path. Look really carefully both above and below the path that the paper takes through the printer. The jammed paper itself can give you a clue about which side the obstruction is on, there wiil often be some sign, such as a bent corner on the page etc. Also check the sliding guides that keep the paper straight, they should be slid in until they are a snug fit with the paper, but not so tight that they stop it from feeding
Posted on Jun 21, 2009
xptareq2000
  • 1447 Answers
SOURCE: how do i load the paper in to canon mx310
Please follow you printer userguide.If you are have no user guide then download www.canon printer support.com
Posted on Sep 07, 2009
My Canon MX310 printer is not printing. The paper feeder is not feeding the paper into the printer. It is feeding only on one side. We are unable to print or get faxes. Can you help me out?
It seems like there are some problem with roller inside..
If you have an air gun, try to get ride of dust as much as u can.
Or if you do not have one, ple use vaccuum cleaner...(at min. power) to **** out dust.
And then try for it.
Apr 08, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 indicates paper jam but no paper
The printer has several switches in it to detect paper jams. When paper feeds in it trips the first one indicating that paper is present. Another switch further along the feed path indicates that the paper is feeding okay.
Your problem can be a jammed switch (loose scrap of paper), a broken switch, a switch disconnected from the controller board or a possible bad controller board.
One thing you didn't mention was does it respond the same with paper loaded? It might be that the first switch is looking for some and not finding it, so it is programmed to assume a jam.
Aug 25, 2010 | Canon PIXMA MX310 All-In-One Printer
My canon pixma ip90v is drawing paper in crooked
Your Pixma's paper holding drawer has adjustable feeding attachments on the front and left side you can use to make sure the paper is square and secure in the tray. This will help your paper load straight.
I hope that helps.
Jul 14, 2010 | Canon Office Equipment & Supplies
Will not feed paper
have you made sure there is nothing inside the printer where you put the paper in at ? the smallest thing in there could keep the paper from feeding through, you may have to turn the printer upside down and shake it a bit,, carefully.. then try to feed the paper again.. ( I am assuming it is a printer and not a fax machine )
Mar 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 keeps not printing and message comes up paper jam sometimes nothing happens sometimes startes to take paper then stops sometimes just feeds through without printing , there seems to be no real...
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Sep 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Jun 21, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper jam crumbles on right side
There is probably I tiny piece of paper stuck in the feeding line on that side. I would use a few hits with dustoff and check close for a scrap of paper
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer Problems
It your printer feeding the paper through?
Need more detail.......
Feb 24, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
310 people viewed this question
old marine
old marine
