Question about Nintendo Wii Console
Wii wouldnt power on, i unplugged it and tried again, nothing.... I read an article above, it worked!! just unplug it from the wall and wait a few minutes, patience is the key here!! only 2 minutes and mine is back on!! great help.... this happens when the unit encounters a change in electricity, like a storm or a surge... it happens even though you dont notice, so before you get too worked up , be patient and try waiting a few minutes before plugging it back in ..thanks
  • 4 Answers
Oooooooo i can help, the wii have to rest a time, and that can hapen becuse the wii need air to. try that ok
Posted on Apr 17, 2009
No power
unplug the wii from the power source then unplug the power source from the wall, wait 30 minutes and try again, if this doesent work leave unplugged for 24 hours.
Dec 28, 2011 | Nintendo Wii Console
Fuse blew now no power tired having it unplugged, tried reset button nothing works
Are you sure the fuse is bad? Mine I have to unplug it from the wall and wait at least a minute and without disconnecting the power supply box from the wii connect to the wall again. If you try to connect the power supply to the wall and then connect the wii to the power supply it will not work.
Sep 14, 2010 | Nintendo Wii Console
When my son pushes the power button nothing happens, it will not start
Hello :
Most power problems with the Wii can be fixed by resetting the [AC] adapter. You can easily reset the [AC] adapter by following these steps:
Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
The AC adapter must remain unplugged at both ends for a full 2 minutes.
It's also recommended you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
While you're waiting, check the AC Adapter for the following:
1:Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
2:Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
If resetting the AC Adapter did not fix your power problems, please continue reading:
3:Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter again (see above)
4:Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
5:Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position , make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
6:Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
7:Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on to verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
8:Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector).
9:Once plugged in, check the power light on the Power button to see if the system is receiving power.
If that didn't help , then I recommend you to replace your Wii with new one if you still have the guarantee !
good luck .
rate please !
Mar 26, 2010 | Nintendo Wii Console
Wii console will not turn on
Try unplug the AC adapter from power cord then wait 30 min and plug it again.If not help you may have a problem with AC adapter.If you have a voltmeter check it.If working your wii need service.If not work just buy another AC adapter.Check online stories in your area.
Nov 24, 2009 | Nintendo Wii Console
Wii will not work. Not even turn on. Not even red light or anything just black.
Try to unplug the AC adapter from the power cord and wait 30 min.Then plug it again.If this not help may the AC adapter is defective.
Oct 16, 2009 | Nintendo Wii Console
Wii console went dead... is there a fuse to reset the thing?
Try unplugging all the cords from the wii unit, wait about a minute or so, then reconnect the cords and power up. This should "reset" the system. A similar situation occurred with our system, and this was the solution we were told to try, and it worked. Good luck! :)
Sep 23, 2009 | Nintendo Wii Console
Wii console not powering on, nothing working.
try this:
unplug the AC power cord from the console and the wall.
wait a couple minutes.
reconnect the AC cord.
hope this helps :D
Jul 14, 2009 | Nintendo Wii Console
No power on for my Wii
Is it plugged in corectly. Maby the plugg.
Jul 11, 2009 | Nintendo Wii Console
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
148 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
