Question about Minolta Office Equipment & Supplies
Touch pad very pale
My Minolta photocopier Di250 has a very pale touch pad screen. I believe it could be the battery. Can you tell me how to get to it please. Many thanks
philippa
  • philippa390 Apr 20, 2009
    Thanks for your quick response
    The Touch Pad is brightly lit, just the print is hardly readable, if I look at it from a low side on position, I can see the text. I cannot see an adjustment on the main screen. There are four 'tabs', Auxilliary; Density; Orig.Copy & Basics, nothing on these screens. Also, if the Touch Pad is very bright - just without text, could this still be a blown back light lamp?
    Thanks
  • Minolta Expert
  • 1,326 Answers
When you say it is pale.... Do you mean you can not read it? There is a display adjustment on the control pannel. If you have adjusted it to the max, you most likely have a blown back light Lamp.
Posted on Apr 17, 2009
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it...
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Touch Panel Adjustment
Functions • To adjust the position of the Touch Panel display
Use
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
Adjustment
Procedure
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Feb 07, 2014 | Minolta bizhub 200 Copier
Cob08 error
If your copier is Dialta 250 reset the malfunction code.
Push the warm restart switch located on the right side to control panel in area of display contrast knob(hole) and enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screenis being displayed.Select the trouble reset and touch exit.
Feb 11, 2013 | Minolta DiALTA Di250 All-In-One Laser...
How to reset the co500 error code from my minolta dialta di250
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
For a new fuse try this site for a start
forf Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Sep 30, 2011 | Minolta DiALTA Di250 All-In-One Laser...
How to change display from Japanese to English
4-2. User’s Choice Function Setting Procedure
<Setting Procedure>
1. Press the User Mode key on the control panel and then touch the “User’s Choice” key.
2. Select the page number key that contains the desired function from among 1/6 through 6/6 shown YOURS WOULD BE 1/6
at the bottom of the Touch Panel.
3. Select the function to be set and make settings as required.
4. After the settings are complete, touch the “Enter” key to validate the settings.
NOTE:
The function selected is highlighted.
<Exiting the Mode>
Perform any one of the following steps to go back to the Basic screen.
 Press the Panel Reset key on the control panel.
 Touch “Exit” on the Touch Panel.
Language Selection
English
Select the language of the Touch Panel messages.
French
Dutch Italian Spanish
Portuguese Danish Norwegian
Swedish Finnish Greek
–Metric Areas–
English German French
Japanese Chinese Portuguese
Mar 18, 2010 | Minolta Office Equipment & Supplies
L cant rest my copier D125if
Aug 27, 2009 | Minolta DiALTA Di250 All-In-One Laser...
Call for service c0f 32
It is very simple just press the first button in the upper part of your keypad the left button then touch the meter count and then type this (STOP 00STOP01 or STOP00STOP01 then touch TECH. REP CHOICE > PRINTER > ATDC SENSOR GAIN then change the number to higher number there are 2 boxes for example. 155 155 touch the first box and erase it using cancel button or C then type a higher number up to 186 desame to the other box then touch END then restart...
Jun 04, 2009 | Minolta DiALTA Di250 All-In-One Laser...
Hi!
TRY THIS
access service mode .by depressing STOP- 00 --STOP- 0 -1
and than select counter, select trouble count and scroll untel you see what that cod means .
get back to me if you need more help
Oct 15, 2008 | Office Equipment & Supplies
Minolta dialta di250
The C0048 error code not exist.Malfunction resetting procedure:
Turn OFF,then ON the power switch or open and close the side cover for all malfunctions except C05XX codes.
Use Trouble reset of the Initial screen to reset all malfunctions.
To right side the touch panel(screen display)near display contrast button exist a little hole (reset switch).Insert a hairpin to touch the switch.
Enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screen being displayed.Touch TROUBLE RESET,and EXIT to go back to the basic screen.
May 07, 2008 | Minolta DiALTA Di520 Laser Printer
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
