Question about Neff U1421 Double circotherm Electric Oven
Neff electric oven ignoring timer settings
I have a Neff U1421N1GB/07 electric oven and have a problem with the timer. The timer display works as does the simple countdown timer function. However, if I try and use the delay start or timed start and finish functions the oven ignores the settings and is on all the time. For example, if I set the timer to turn the oven off after 30 mins there is a click as the timer reaches zero but the oven stays on.
I am planning to take the oven out to replace the fan motor which is showing its age and sometimes needs to be encouraged to start. If I know what component controls the oven on/off from the timer I could replace that at the same time.
Any advice (or better still a part number!) would be appreciated.
Thanks
barkencoa
  • 3463 Answers
SOURCE: Neff B1442 Oven -- Defective timer and clock
Hi.
Is it flashing AUTO, If it is and you can'y reset it back to manual, then you have faulty timer.
Hope this helps
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
  • 44 Answers
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Posted on Mar 19, 2009
SOURCE: Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
Posted on Sep 11, 2009
apart4u
  • 213 Answers
SOURCE: Neff fan oven dead. Where do I look next? I've
this could all so be the timer For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 12, 2010
Changing the time on a Neff oven B47CR32NOB
Press the select button until the clock flashes ( you do this by looking at the time displayed and pressing the select button as required) Use the timer set button by rotating to correct time. Once the time is displayed wait 2 seconds for it to set.
Oct 29, 2016 | Neff Ovens
My Neff oven is displaying the locked "key" symbol...does anyone know how to unlock please?
Locking the oven:
Using the main oven function selector, switch 3 x in
rapid succession from the 'off' position to the
oven light function and back again.
- s - is displayed.
The oven cannot be unintentionally
switched on, e.g. by children.
To release the oven, switch 3 x from
the 'off' position to the oven light.
- s - goes out.
Mar 21, 2013 | Neff B1641 Single circotherm super...
Power failure,now 000 is flashing on oven exterior
If the 000 is on the display left of centre, then you possibly just need to reset the clock. from left to right-....press the first button to activate the clock setting phase....press the next button to pop out the rotating timer adjust and set the time.
If it is the display above the centre control dial pls repost with the full Enr from the rating plate.
Feb 25, 2013 | Neff B1881 Single circotherm super...
How do I set auto timer on my neff oven to come on In a couple of hours ?
Here is the link to a short PDF file that explains a couple of setting on the Neff oven, including the automatic timer:
http://www.neff.co.uk/files/Getting_Started_Leaflet.pdf
Hope this helps. :)
May 20, 2012 | Neff Ovens
Er 07
i can't help you with this brand but in almost all oven of this type . inside behind the display board is a tech sheet. it will have all the answer's fault codes are a common way for self diag ovens and other appliances .. mm
Jul 14, 2010 | Neff B1421 Electric Single Oven
Candy Electric Oven no power in oven/grill at all, only clock
is the timer set, most ovens wont work if the timer is not set
Apr 07, 2010 | Neff U1421 Double circotherm Electric Oven
Neff B1428
If it is a digital timer and u have display, thenyou must make sure it is set to manual and not flashing auto, or the oven will not work.
If it is an anologue timer tweak the knobs until you can see a hand symbol showing this is the manual mode.
If no display of any kind, and u are sure u have a supply to oven then timer could be faulty.
Hope this helps.
U must ensure that u have a supply to the oven befor trying to alter timer.
Plz rate solution.
Thanks.
Dec 31, 2008 | Neff B1428 Nostalgic Single circotherm...
Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
Nov 28, 2008 | Neff B1432 Single circotherm plus Electric...
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
TOC
hi there if your toc is at fault you will have no oven function at all ie. fan, light, and timer display. i would first check your timer is not set to auto and is also got the time set, failing that your thermostat may be at fault.
May 22, 2008 | Neff U1661 Double circotherm super...
Neff U1421 Double circotherm Electric Oven Logo
194 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
