Question about MSI /865PE NEO2 PLATINUM ED. Motherboard
Auto restarting, my pc is having hard start and auto restart, its a p4 2.4ghz w 512mb ram, it doe not hang or freeze but sometimes when you turn it off it does not turf off but restarts, sometimes after shutting it down normally i encounter hard start meaning power is all ok everything is running but no post trrying to turn off thru psu switch 4 or 5 times then it will power on, anyone pls help im having so much headache with this mobo,.
  • 3,267 Answers
I think a general cleaning including the contact points of the RAM and checking that all wires are snug tight including all jumpers are properly seated. If required clean the PC power switch with a spray of alcohol/spirit. After all these I hope your problem disappears.................sodeep
Posted on Apr 17, 2009
I have NEC versa S3200.. Was using windows 7...and wanted to turn it back to XP SP3. Formatted the drive and finished installing XP SP3...now it freezes on the NEC screen
Sub out the ram one at a time testing as you go, if that fails you may have a hard drive issue, remove hardware and reseat it back in place, sometimes it will restart, if it does not! try formatting the hard drive again with the XP disc and a re-install, make sure disc is spotless before you start, just might make the difference.
Mar 20, 2012 | NEC Computers & Internet
My pc was working fine with 128 + 256 ram. few days ago it didnt boot.it was restarting automatically. then i removed 256 ram and it booted normally.means pc works normally with 128 ram but not with 256...
i guess u have 2 different RAM cards in the RAM slots....
the main issue is both dont work together...the primary reason is compatibility....or one of the RAM cards have worn out...
u must use exactly similar kind of RAMs in both slots....
i suggest u use one 512 MB if your motherboard supports....
RAM technology has advanced so mush that you wont get RAMs for old PCs (motherboards)....so u decide...
pls revert back...and kindly leave a feedback and rating for this solution...it will help me move to Guru" here from Expert at Fixya....
regards...
Sep 29, 2010 | Gigabyte GA-8I845GV Motherboard
Dell inspiron 9300 getting hang or restart after every 15 min
Sounds like your hardrive is starting to fail-backup all files!!!
Apr 12, 2009 | Dell Inspiron 9300 PC Notebook
My PC freeze and restart while I play ANY strategy game
Have you reinstalled the specific games you are playing? If not, try that. If that does not work, write back.
Nov 21, 2008 | Computers & Internet
Computer won`t start
Hello there my friend
There is a easy check, it sometimes MEMORY PROBLEMS, or VIDEO , check your RAMs, and take out one module, if has more than one, and restart the PC, I know you will write me back! :)
tell me!
Open Sky
Sep 19, 2008 | Everex GA3400 Refurbished AMD Desktop...
PC Freezing !
Update BIOS to P25 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&Inst=Yes&ProductID=948&DwnldID=10130&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
Reset BIOS to default settings.
Check CPU Temperature, Prescott CPUs run hot.
If board is under 3 years old and was a retail box package, it will be under warranty, contact Intel.
Jun 29, 2008 | Intel Motherboard
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Computer has power but won't start up
at the start up press F8 within 5 seconds and then select las t good know and then restart the computer if this does not help you may have to repair windows or change hard drive
Jan 03, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Home pc
hello,
try this,
click on start then run, type msconfig in command box,
system configuration window should show up. click on tab called startup. click disable all, then apply, then click ok, it should ask if u want to restart. please restart the computer.
what will it do? it will disable all startup applications.
if this resolves the issue, then you would know its one of the startup application causing your computer to freeze it.
also right click on bottom bar, then click task manager.
click on tab called processor.
average processor is 25-30.
in my laptop i have only 19 processor runnning.
if you have alot of processor running that definitly cause PC to slow/freeze.
hope this information help you
Dec 22, 2007 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Pc is not working
as computer starts hold down F8 and youll see a safe mode. use the safe mode and it might just come back, restart it....sometimes strange viruses does this but i dought in your case.it should come up in safe mode allowing you to save your files ...folders to cd record disks...then you can format and reinstall all programs.
Sep 01, 2007 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
MSI /865PE NEO2 PLATINUM ED. Motherboard Logo
140 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
