Question about RCA HD52W59 HDTV Projection Television
Lines in Tv and pic looks distorted
We turned it on and the game looks like double and the players have a red shadows when we turn it off there is some lines of diffrent colors this just happened...
    Genius:
  • 1,153 Answers
Convergence problems, try to go to menu and set if will not set then you may have problems on board. You may have to change amps. Replace return resistors too!
Posted on Sep 17, 2007
SOURCE:
When I first turn on the TV the picture is messed up sometimes it shows a double picture.If I turn it on then off and back on again the picture is fine.Whats wrong? My second problem is that when I turn on...
Ur tv covergence board it is dying.Tv are developing a convergence picture problems.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it dying must require replacement like 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 30, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Hitachi 53SWX01W Distorted red lines and shadowing.
that is from a bad video board..try turning it off to reset the values, but I'm not confident it's recoverable without some serious technical help
Apr 27, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Color distortion, hazy snowy screen with thin red lines, suddenly happened had perfect pic 24 hours ago
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi VS-50705 50" Rear Projection...
The red coler has started to curve about a third of the way down the screen. everything on the the screen is distorted and doubled in red
if your picture looks 3d it is convergence problem.
This is a do it yourself repair if you have some skill.
I will tell you what you need and have start to finish, step by step instructions for this repair along with photos, and source for parts needed(parts cost will be under 30 dollars).
reply here if I can help.
SD TECH
Oct 24, 2010 | Mitsubishi WS-55807 TV
Objects are doubled and colors are distorted
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2010 | RCA R52WM24 52" HDTV Projection Television
Red distortion!
hello it sound like the convergance chips have gone to be fair the to the engineer its a big job
i hope you get it repaired good luck
shaun
Aug 04, 2009 | Televison & Video
Red bowed horizontal lines
Projection sets have two very common problems outlined below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
bb0cf99.pngSOLUTION
May 17, 2009 | Hitachi 43GX01B 43" Rear Projection...
Shadows double vision
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Apr 19, 2009 | Hitachi 50FX30B 50" Rear Projection...
replace the conv ic,s stk392-110 and ck for any bad rest in that circuit
Apr 14, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Red shadows and mild distortion
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
Apr 03, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
